85 revived
pc85
Mine's an 84 LS. Do you have any details on the 88 airdam? Did you heat up the sides with a heat gun to fit them to the fenders? Looks like you got it to fit perfectly! FlaTTy LOVE :wub:
Wow '84, looks bran new! It's an '89 not '88 and was actually cheaper (like $300-7 yrs ago at a Mitsu dealer) than the 3 piece. It's not heated or treated specially, just made some brackets out of aluminum straps, cut and formed to fit, screwed to the corners to pull in the ends and bolted to the undercarriage. The end is a little longer than the fender and extends a little over 1/4" into the tire well, no biggy , love the look with the IC.
http://i849.photobucket.com/albums/ab51/pc85dr/IMG_0337-1-1.jpg
Edited by pc85
  • 2 weeks later...
Got her home, finally!!! She's about 95% needs a little tuning, running very rich. Looks incredible but not running as good as she looks yet. The morning after I picked her up, wouldn't start, she flooded, had to unplug injectors, clear cylinders, play with gas pedal and finally got her started. So next step is Swift Racing Technologies in D.C. for fine tuning and Dyno test., should put out >300 hopefully 350 hp.
  • 4 weeks later...
  • 2 weeks later...
Exactly, Its time for a Winter break. I'll be taking the tires/rims off, getting her up on jack stands. Have to work on establishing exact off-set for some custom 17" rims. In the Spring, taking her down to D.C for some fine tuning at SRT (Swift Racing Technologies). For us Mid-Atlantic guys, they are a custom high performance shop dedicated to Japanese cars, they can fabricate almost anything and are Haltech specialists for my ECU.
  • 1 month later...
OK, time for a little catching up. Here are some pics of the calipers I had powder coated when I overhauled the brakes. All new TEP rotors and pads. After the paint job, this was the second phase of the resto finished in Summer of '08 almost four years ago.
Front passenger side:
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1044-1.jpg
TEP kevlar pads
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1049.jpg
TEP SS brake lines
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1046.jpg
driver's side, front
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1047.jpg
TEP kevlar pads
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1048.jpg
TEP SS brake lines
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1051.jpg
passenger side, rear
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1116.jpg
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1126.jpg
TEP SS brake lines
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1117.jpg
driver's side rear
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1122.jpg
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1125.jpg
TEP SS brake lines
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1123.jpg
Wow, how time flies almost four years ago and I thought I'ld be done by now and I'm only half way there. Still need:
1, Rims and tires
2, Custom interior/stereo
3, New paint job.
Edited by pc85
Got a chance to take some pics of jolyrgr's 3" SS exhaust while the car is up for the Winter:
New Innovate wideband O2 sensor, adequate distance from turbo
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1127.jpg
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1118-1.jpg
only issue with the fitment, a little close to the sway bar
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1121.jpg
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1120.jpg
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1119.jpg
Overall very tight fit and incredible sound.
Edited by pc85
Had some time for a little upgrade while its up for the Winter: Hood Struts!
MotoCam360's complete kit
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1102.jpg
Marked measurements on painters tape, much easier to see.
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1103.jpg
Screw hole, make sure its CENTERED
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1107.jpg
Passenger side strut
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1108.jpg
Bracket
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1109.jpg
Passenger side strut assembly
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1111.jpg
Driver's side strut assembly
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1110.jpg
"Look Mom, no bar"
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1112.jpg
This is a must have for all, easy bolt on took me one hour total instal time. Love it!!!
Edited by pc85
  • 1 month later...
OK so decided to do some detailing, moved some things around to de-clutter and and take care of some loose ends.
Changed all the t-bolt clamps on the HPs for standard hose clamps. Call me crazy but they're much easier to adjust and a lot less bulky, so they're gone.
Moved power steering reservoir to front by AHP. Was in the passenger side with the Greddy boost controller solenoid, Innovate wideband; too much
http://i849.photobucket.com/albums/ab51/pc85dr/IMG_1158.jpg
Relocated rad overflow tank to a more OEM position
Mounted A/C idler arm
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1140.jpg
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1141.jpg
Changing heavy plastic fan for an aluminum Flex-lite fan
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1142.jpg
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1143.jpg
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1144.jpg
Have a clearance problem, need to make a spacer
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1145.jpg
Started going through remnants of stock harness. Uncovered 27 yrs of grease and grim.
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1147.jpg
Fished out harness saving 4 wires.
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1152.jpg
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1153.jpg
Good buy junk
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1154.jpg
Wrapping new harness.
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1155.jpg
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1156.jpg
Found relay with 2 wires clipped, 1 wire still connected? What's this relay for anyway.
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1159.jpg
And found this fuse relay clipped on 1 of the 2 red wires.
http://i849.photobucket.com/albums/ab51/pc85dr/IMG_1160.jpg
Can someone let me know if those clipped wires have anything to do with the relays/fuse working properly?
Started tucking the new harness
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1157.jpg
Grease is gone, clean but not the right color? Supposed to be Kona blue, looks like someone took a lot of short cuts LOL.
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1162.jpg
Still have to work on the spacer for the fan.
Edited by pc85
Finished tucking new harness and got around to finishing the spacer. Last weekend got some longer bolts, spacers to fit over bolts and mounted fan but it looked like some big flying saucer on 4 stilts. Being the home improvement guy that I am, went down to my shop and found something to beef up the little stilts:
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1164.jpg
That's right MDF, LOL! One was too thin so I glued a second for a total of 1 1/2" then cut it down to exactly 1 1/4".
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1165.jpg
Placed the spacers through mounting holes
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1169.jpg
and wrapped the MDF puck in metal tape
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1170.jpg
Mounted fan with plenty of clearance. All the stress is on the metal spacers and washers, the MDF puck is more of a filler and stabilizer for the metal spacers. And it looks better. This will be a temporary solution untilI find a machine shop to make an complete spacer out of aluminum.
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1171.jpg
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1172.jpg
Hope this works.
Shroud definitely. Fitment is fine, mine is a 17" and the shroud fits perfectly. But you will have to space it out about 2' from the pulley like I did and BTW make sure you mount it in the right direction LOL. Rookie mistake. Edited by pc85
This what came in:
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1180-2.jpg
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1181-2.jpg
Mounted for clearance and fitment:
http://i849.photobucket.com/albums/ab51/pc85dr/85%20Revived/IMG_1191-2.jpg
Now just got to get some tires on those bad boys.
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
