DISTRIBUTORLESS IGNITION
FuelinjectionPro
Many have asked for it and now it's here!
We now have a distributorless ignition system made for the Conquest and Starion. The ED-IS-ON Ignition system is easy to install and ready to run.
We designed a crankshaft pulley with trigger teeth built in, and as a bonus it a underdrive that saves power!
It is a standalone system and can be used on cars that are stock, have one of our FuelinjectionPro's TB-PRO or HURRICANE-4 systems and most
aftermarket fuel ECU's.
http://www.angelfire.com/mech/edwardcase00/edison/EDSION2A.jpg
This system replaces the stock ignition system.
Installation is easy -- remove the old ignition-- Bolt the new parts in place, plug in and connect the power.
No guess work or trying to mount trigger wheels to the old stock pulley.
You can program all timing advance, retards, and boost retards with our IgnitionPro Software. There are even two outputs that can control shift lights, fans(requires optional temp sensor) and nos. Includes outputs for the stock tach and aftermarket tachs. There is an alternator overdrive pulley option for those that would like to keep there alternator at the stock drive speed.
The list price will be $875.00
We are offering these as a group buy price of $795.00 with a deposit of $395.00 and the balance due when the group buy closes.
If you already have one of our IgnitionPro1 systems and want to convert to distributorless , please contact us.
If you would like to buy this and one of our fuel system kits, contact us for a price.
Turbo_boosted@hotmail.com or Phone 727-243-1396
Ed
Looks good Ed, question, does it have provisions for a rev-limiter?
Oh, and ED-IS-ON, good one!
What about a two-step? Does the controller have any inputs for the knock box, or other type of knock sensor, or for nitrous retard?
As far as the pulley is concerned... will there ever be any possibility of getting a crank-trigger harmonic balancer pulley?
Is the pulley / sensor availible seperately? Price?
Thanks!
(A) Yes, the rev limiter can be added as an option any time.
(B) Thanks, Scott named it.
(A) A two step rev limiter is an option.
(B) Yes these are options, the knock sensor requires a signal conditioner.
© No, the pulley is soild, also the stock pulley provided very little damping and we have noted that it does not stand up well to high rpm use.
(D) The pulley and sensor bracket will be available. We are still working out prices.
what % underdriven?
It is about 15%.
? that system control fuel?
The ED-IS-ON is ignition only, we do have systems with the ED-IS-ON ignition and fuel control for MPI setups at $1290.00. Also any of our TB-PRO or the HURRICANE-4 MPI can have the ED-IS-ON ignition as an option.
How much for the kit without the computer?
We feel that the complete system is the best buy and it is easy to install. Also if there are problems we offer very good support for our systems. But we know that some may like to use parts of this kit for other setups.
Please contact us and tell us what you will be useing it with. Also we can make the harness as needed.
Ed
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
