Banky Posted August 3, 2002 Report Share Posted August 3, 2002 Has anyone with the fiberglass hood tried fitting the stock 83 hood plastic inserts into the side vent areas? I have a pair, and was curious if its possible. Justin Link to comment Share on other sites More sharing options...
tux Posted August 16, 2002 Report Share Posted August 16, 2002 i want to do that but i need the hood (and finish paying) and vents to try ;D Link to comment Share on other sites More sharing options...
SQF Posted August 17, 2002 Report Share Posted August 17, 2002 The side vent MAY work but the front scoop is modified to be more sturdy. I don't think the front insert would fit in the new and improved opening. I've never seen an insert out of the hood to be sure. Link to comment Share on other sites More sharing options...
GPN Posted August 17, 2002 Report Share Posted August 17, 2002 I do not see why you could not, it will depend how thick the hood is in that area. The thickness would determin how to attach the inserts, if there is enough material to cut the area under the insert flange to form a lip for the flange to rest on. Then it would be a matter of how to adhere the insert. If there is not enough material(hood thickness) then a bracket or more glass strips could be added to form a "nest" for the insert to rest in and held by. GPN Link to comment Share on other sites More sharing options...
TM Posted September 6, 2002 Report Share Posted September 6, 2002 Just FYI, the 2 side vents are not plastic, although the front, center one is. Since they bolt to the under bracing, I doubt you could use them in a FG hood. But I would think you could cut or paint the FG to make it look the same. Link to comment Share on other sites More sharing options...
