TM
About TM
- Birthday 02/19/1947
MSN
temccann1@msn.com
Website URL
http://
2 '89 Quests & 3 First Gen Camaros
Littleton, Colorado
80128
1989
Rio/Mexican Red
Restoring
4823 profile views
TM's Achievements
Thanks. I found one locally, but it was an adventure plus $475. And then there were the 6 clips for the trim. I had to order 4x needed online or pay more for S&H than the clip, so if anyone needs some LMK. They are little plastic clips that hold the trim above the windshield in place, and most of mine are broken. Easier to replace while the windshield is out, especially if one of their mounting studs breaks, and must be replaced with a screw.
TM started following Windshield 1989
I'm looking for a windshield and wondered whether anyone had a good source. I'm near Denver, CO
I'm with BC_99. A little less BS would be appreciated. Let's grow up and use this site the way it was intended.
I just spent the morning painstakingly locating the hole perfectly to install a set of hood struts (I didn't see any mention of the fact that 8" puts the hole exactly on a body seam, so it's edge first has to be ground down to avoid affecting the drilling of the hole, which is still difficult due to clearance between the drill and inner fender well needed to keep the hole centered vertically) only to discover what everyone else on this thread found: they can't be used with an '83 hood! I took modeling clay and discovered that the problem is that the front strut pivot hits the side vent's front fastener, and depression in the hood the vent sits in. This area can't be drilled out and likely wouldn't give much clearance or address the fastener problem. The front stud on the side vent might be shortened and a speed nut used to hold the front of the vent insert in place, but there wouldn't be any room left if it did. And I'm not for cobbling. I looked at moving the pivot forward an inch or so, but the shaft from the strut would still occupy this area, which must be pretty tight with the hood closed. I'm bummed and in no mood for this! These had been available for some time before I bought mine, and I hadn't seen anything but praise for them. And they do work nice; just can't close the hood! I thought most remaining StarQuest owners had '83 hoods, but either many don't, or they just slammed the hood when finished, and called it good. BTW: I tried to go to Tim's (MotoCam360's) web page, to see if this issue was addressed, but it's been down for awhile. If I don't see a response here, I'll call him. I'd hope he posts this on his ebay ad or elsewhere they are sold, if a workable arrangement cannot be found for this configuration. Too bad as it was a nice addition/package. -Tom
I have an older set that doesn't have the socket (Allen) heads, and I don't know about torqueing the stud into the block with it. Did you get this from ARP? If you do this, it will pre-load the threads against the bottom of the hole in the block and increase the load on them when you torque the nuts on. The torque value on these studs (or bolts) is based upon stretching them the proper amount, and I think the preload will affect that. Since ARP is concerned with the lube used, I think they want the stud free to rotate so the stretch is between the threads of the stud. I've never heard of them backing out, so I wonder if they were properly torqued. (Including the individual loosening and re-torqueing after a full heat cycle, as prescribed.)
Msg sent
I bought an '89 ETACS from Dan on Friday and it arrived on Monday. Good price and great delivery service! So fast one would think it came to Colorado from neighboring Wyoming, instead of Delaware!
FYI: These (KYB) struts were originally gas charged (the oil in them was under pressure to avoid foaming under extreme conditions), which causes them to extend unless restrained. When they no longer do this, the gas has escaped. But this does not affect their functioning under normal conditions or indicate they are leaking (oil).
PM sent on pink label'd
Looking for a good MB 606956 ETACS unit. This is the metal box under the driver's seat, and this PN was used in StarQuests built after June of 1988.
Hi. Wondering whether you solved this problem, because I believe I have the same. Was your problem constant, or intermittent? I was able to regain power by removing the 'Ign' fuseable link and cleaning the terminals, but the problem has returned, so I suspect the removal and reapplication of the power temporarily restored the system. I've come down to either the Starter Inhibitor Relay (A39X) or the ETACS. I may differ with Shelby if he is referring to this relay, as the schematic for the Starting Circuit (1, Pg 8-45 in the '89 Vol 2 SM) indicates that power from the Key Reminder provides the power to this relay to close the contacts to the starter solenoid. Thereby requiring a key in the ignition switch prior to engaging the starter. The ETACS comes into play because I noticed the shoulder belts began to close when the car resumed starting, and provides the SI relay's winding the ground required to operate, through a transistor.
PM sent for injectors
Selling every starion part i have! Interior mostly some body
TM replied to Starionslider's topic in Parts for sale
Interested in black cabin carpet if it is in excellent condition. Plz send pics and details, including year & any irregularities. -
I bought a pair of Autospecialty Power Stop drilled rotors and Axxis Metal Master brake pads from David at a good price, and with him picking up the shipping. But he sent them express, at much greater cost to himself. I'd happily o more biz with him. -Tom
