Antenna Not Going All The Way Down
Contsi
87 Quest
Goes all the way up every time with radio power. On rare occasion  it will go all the way down.
It stops at various height on the way down.
Could this be slipping from worn nylon gear therefore no fix or could it be repaired?
Thanks
Agreed. I had a similar situation a few years back. Take it all apart, clean it up and coat it with white lithium grease and see what happens.
Unfortunately the nylon snake broke, it's very brittle.
anyone know of a mast replacement source?
I had another car with similar set up, the mast broke and I was able to feed a replacement into it.
Thanks
If you do it, please document it.
Totally for me.  I might repair mine if Jan doesn't do a CF wing replacement of stock size with antenna shave.
Here is what it looks like installed: https://ibb.co/mT5p2cb
I trimmed about 6 inches from the nylon cable (not sure you need to).
I noticed that this mast is skinnier than ours, but as long as it  doesn't pass the outer ring, it will stop when it goes up.
Also, notice that the tip is different. I prefer ours.
It's very easy to take out the mast, I can slide mine back in since the actual mast is not broken.
I'll keep looking for the correct length, if anyone comes across something, please let me know.
Thanks
How to cast a snake would be a more popular thing to cast. People use some type of dough or silicone to make a mold and then pour the material of your choice for the part.  Lots of videos on the tube on how to cast at home.
