TexasQuest Posted November 8, 2015 Report Share Posted November 8, 2015 Are all year starters interchangeable? 240mm or 225mm flywheels make no difference? Link to comment Share on other sites More sharing options...
M Code Posted November 8, 2015 Report Share Posted November 8, 2015 They are different... Just my $0.02... Link to comment Share on other sites More sharing options...
nightwalkerancestery Posted November 8, 2015 Report Share Posted November 8, 2015 They are not different. The only coherence between the two flywheels is the friction surface. The ring gears ate both the same. Running my 87 starter with an 88/89 flywheel currently. Engages fine. Should be good to go. - Charles Link to comment Share on other sites More sharing options...
nightwalkerancestery Posted November 8, 2015 Report Share Posted November 8, 2015 Oh, and I just verified it through part numbers. The pre-88s have the same starter part number as the 88/89 flys. - Charles Link to comment Share on other sites More sharing options...
ucw458 Posted November 8, 2015 Report Share Posted November 8, 2015 The 87, 88 and 89 FSM states all starters have a 9 tooth gear and a 1.2 kw motor. There may be some un-published differences between auto and manual but they are minimal. I remember reading somewhere that auto trans starters had an 8 tooth gear but I can't confirm that. Link to comment Share on other sites More sharing options...
TexasQuest Posted November 10, 2015 Author Report Share Posted November 10, 2015 I think there is a difference in auto and manual cars. It gets even more confusing in earlier years with different engine VIN's. Link to comment Share on other sites More sharing options...
TexasQuest Posted November 10, 2015 Author Report Share Posted November 10, 2015 From what I've gathered thru research is the 83-86 cars had an auto-manual option 8 tooth starter, transmission specific. Starting in 87 until 89 all transmissons used the 9 tooth starter. Link to comment Share on other sites More sharing options...
