mbruneaux Posted September 8, 2015 Report Share Posted September 8, 2015 The PO rebuilt the engine and installed a new head, since then it's sat for about two years barely running. Since I have the valve cover off would it hurt it to re-torque the head? I'm certain he used Fel-Pro. Thanks Link to comment Share on other sites More sharing options...
stariondreams Posted September 8, 2015 Report Share Posted September 8, 2015 I would say no unless it was ran hot. But some will say yes . I think you will be fine. how close is the car she ready to cruise? Link to comment Share on other sites More sharing options...
mbruneaux Posted September 8, 2015 Author Report Share Posted September 8, 2015 I would say no unless it was ran hot. But some will say yes . I think you will be fine. how close is the car she ready to cruise? It's getting there, I'm in the middle of replacing a lot of bad parts and replacing marginal pieces while access is easier. I've had it running and driving for a few months but not 100% Link to comment Share on other sites More sharing options...
tsi_tom Posted September 8, 2015 Report Share Posted September 8, 2015 I retorqued mine after it was run. There was some bolts that needed it. Link to comment Share on other sites More sharing options...
button Posted September 8, 2015 Report Share Posted September 8, 2015 I wouldn't say re-torque, since you didn't do the torquing originally.I would personally check the torque on them if the valve cover is off. Link to comment Share on other sites More sharing options...
starquestJOE Posted September 8, 2015 Report Share Posted September 8, 2015 I check my studs every time I change the oil. I dont re-torque them but I make sure they click Link to comment Share on other sites More sharing options...
Tim_C. Posted September 8, 2015 Report Share Posted September 8, 2015 It can't hurt to re-torque. I doubt the PO did, so you really should do it. It is a good idea because the new head will move some and find it's spot so to speak. This will always loosen some bolts like Tom said. Loosen them up one at a time and retorque before going to the next one. Link to comment Share on other sites More sharing options...
mbruneaux Posted September 9, 2015 Author Report Share Posted September 9, 2015 Thank you for your responses, I will retorque them. Link to comment Share on other sites More sharing options...
stariondreams Posted September 10, 2015 Report Share Posted September 10, 2015 It's getting there, I'm in the middle of replacing a lot of bad parts and replacing marginal pieces while access is easier. I've had it running and driving for a few months but not 100%I know that feeling I drive mine from newbritain to clinton and let me tell you i found all the problems .Rt 9 is the perfect test road hills strait a ways and at the right time almost no traffic Link to comment Share on other sites More sharing options...
mbruneaux Posted September 10, 2015 Author Report Share Posted September 10, 2015 I know that feeling I drive mine from newbritain to clinton and let me tell you i found all the problems .Rt 9 is the perfect test road hills strait a ways and at the right time almost no trafficWhere in CT are you? I'm in that part of the state often. Link to comment Share on other sites More sharing options...
