81zfan Posted July 10, 2015 Report Share Posted July 10, 2015 It's been a while since I've been on here and the quest has been shoved to the side for a while,but I finally got it running and I'm going at it 110% now. Question is... I was letting it idle today and was adjusted stuff and noticed antifreeze dripping out of the floor. I looked under the dash and could see it running down wires and such, so my guess is, it's the heater core! Is there a easy way to replace this or is it one of those"tear into it till you get it" things. Does anyone have a "How to" on this or is there a write up on here? I've searched a little but couldn't really find anything with much helpThanks guys!! Link to comment Share on other sites More sharing options...
importwarrior Posted July 10, 2015 Report Share Posted July 10, 2015 Nooooooooo not that.Couple of things come to mind... One for sure the 2 inch hose on theHeater core is leaking. Second thought is that the head might be crackedBetween the valves. When boost is created it puts boostPressure in the radiator system and forces past that small hoseOn the heater core. Or just simple radiator pressure is passing by the little hose. The BAD is the entire dash and all that is there including the bracketsNeed to come out to replace said little 2 inch hose. If your replacing that hose might as well get new hose clamps andDash speakers and replace and lube all the stuff back there. Check FAQ for how to do it. Link to comment Share on other sites More sharing options...
importwarrior Posted July 10, 2015 Report Share Posted July 10, 2015 The most neglected hose on the car. http://www.starquest...howtopic=107140 . Link to comment Share on other sites More sharing options...
81zfan Posted July 10, 2015 Author Report Share Posted July 10, 2015 Well it is running down the passenger side only, and I mean RUNNING!!! I can see it wet right in the center behind the radio and stuff almost against the firewall. Talked to Dad a min ago and was explaining to him what it was doing. when at idle it has like a bubbly/trickly/ gurgle sound.I've been running the car for a couple day...not driving, just idling and reving. HahaIr's not been leaking any that I could tell until today.I hope like hell it's not a head or something that major! Head and engine is 4 years old but only has 600 miles on it Link to comment Share on other sites More sharing options...
81zfan Posted July 10, 2015 Author Report Share Posted July 10, 2015 Oh I forgot to mention. I wasn't driving or anything of that nature when I noticed it, it was only at idle and did it continually..that sound led me to believe it was the Core because I have experienced it with other car's Link to comment Share on other sites More sharing options...
importwarrior Posted July 10, 2015 Report Share Posted July 10, 2015 Yup that's it. Don't run it till you fix it. You need to remove the entire das like the link shows. Link to comment Share on other sites More sharing options...
81zfan Posted July 10, 2015 Author Report Share Posted July 10, 2015 Geeeeez!!! I've always dreaded when that time would come!! Link to comment Share on other sites More sharing options...
81zfan Posted July 10, 2015 Author Report Share Posted July 10, 2015 Oh, I have not intentions on running or driving the car right now. I'm just trying to get it ready to drive before another year comes and goes. I appreciate the link and the help. I just have to motivate myself to do this now Link to comment Share on other sites More sharing options...
Preludedude Posted July 10, 2015 Report Share Posted July 10, 2015 Don't have heat. Bypass the firewall hoses. You don't really need heat. That's what I did. But then again, mines not a daily. Link to comment Share on other sites More sharing options...
81zfan Posted July 10, 2015 Author Report Share Posted July 10, 2015 That was my initial thought when I found out the problem. Mine is Def not a daily, so I guess I'll weigh my options and go from there Link to comment Share on other sites More sharing options...
importwarrior Posted July 10, 2015 Report Share Posted July 10, 2015 Maybe I am wrong but maybe you can do a radiator Pressure test. Remove spark plugs and see if youCan hear anything in the cylinders. Link to comment Share on other sites More sharing options...
87redcat Posted July 10, 2015 Report Share Posted July 10, 2015 If he's only got 600 miles on the build I'm going to lean toward the 2" hose. Bypass the heater core and confirm the leak has stopped. Make plans to pull the dash when you have a weekend free. Take lots of pics so you can put it back together correctly. and dont forget to unplug the clock or it will explode when you pull the dash out. Link to comment Share on other sites More sharing options...
81zfan Posted July 10, 2015 Author Report Share Posted July 10, 2015 I'm goin to pressure test it before I do anything, and then I'll go from there,I wanna take my time and do it right if I end pulling the dash, I sure don't wanna bust it or anything.I've heard that clock is a tricky little thing. I'll have to make double notes to unplug it Link to comment Share on other sites More sharing options...
importwarrior Posted July 10, 2015 Report Share Posted July 10, 2015 the clock is easy just need 2 butter knives or something thin to get in the sides to push the retaining tabs inwards towards the center of the clockthen it slides right out. look for a pic of a clock all ready taken out and you should see what i mean. my only problem was reconnecting all the relays and connectors. there was one i missed and it took a day and a half to figure out where it was but i got it. the car would not start.... the good thing is you can do the heater BOX refresh. grease al the mechanics of it and replace the dash speakers. Link to comment Share on other sites More sharing options...
importwarrior Posted July 10, 2015 Report Share Posted July 10, 2015 one of the best heater box rebuild posts. http://www.starquestclub.com/forum/index.php?showtopic=131748 hope it helps. Link to comment Share on other sites More sharing options...
importwarrior Posted July 10, 2015 Report Share Posted July 10, 2015 how to remove dash. http://www.starquestclub.com/forum/index.php?showtopic=138420 hope this helps Link to comment Share on other sites More sharing options...
81zfan Posted July 10, 2015 Author Report Share Posted July 10, 2015 Thanks Import for all the info and help on this subject. It looks pretty straight forward once you get the cluster and stuff out of the way. I'm gonna do the pressure test this evening and then start on taking the dash out or I may just re-route it and run it through the A/C lines 1 Link to comment Share on other sites More sharing options...
ucw458 Posted July 10, 2015 Report Share Posted July 10, 2015 If you use the AC evaporator core for heat you can never use it for AC again. The contamination that will get inside the evaporator will prevent the AC from ever working again unless you replace the evaporator. Best just to do it right and replace the hose. Not hard to pull the dash and a good quality hose will last 20+ years. Link to comment Share on other sites More sharing options...
