CaliConquestAlex Posted April 3, 2015 Report Share Posted April 3, 2015 (edited) Any tips on tuning spark\ignition advance to improve off boost response or to reduce turbo lag with a big turbo? Edited April 3, 2015 by CaliConquestAlex Link to comment Share on other sites More sharing options...
Funky Phil Posted April 3, 2015 Report Share Posted April 3, 2015 Are you monitoring EGT? Ignition retard in the lower "transition" boost regions will spool the turbo, but at the cost of A LOT of heat. More cruise ignition will give you better throttle response.A different cam will also wake it up and would be something I would take a good hard look at. Link to comment Share on other sites More sharing options...
CaliConquestAlex Posted April 4, 2015 Author Report Share Posted April 4, 2015 (edited) I plan to install an EGT sensor soon as I know that can be very valuable for tuning. Edited April 4, 2015 by CaliConquestAlex Link to comment Share on other sites More sharing options...
CaliConquestAlex Posted April 4, 2015 Author Report Share Posted April 4, 2015 (edited) Also, I've kept the car quiet rich in all areas with the off boost area maxing out at 13.5 afr. I know I can lean it out for more power, but I'm nervous to go too lean and fry something Edited April 4, 2015 by CaliConquestAlex Link to comment Share on other sites More sharing options...
psu_Crash Posted April 4, 2015 Report Share Posted April 4, 2015 You can safely lean things out a good bit in the off boost, low load areas. Being a little lean going into boost also helps to spool things up quicker, but it's not the safest practice, especially on a street car. So I avoid that.Here's my target table for reference. I have been told that the stock ECU keeps things at stoic until you begin going into boost, but again that makes me nervous.http://imageshack.com/a/img673/5156/kONYLl.jpg Link to comment Share on other sites More sharing options...
87quest-TSI Posted April 4, 2015 Report Share Posted April 4, 2015 are you running duel tables?That table you posted dose not have any boost. Link to comment Share on other sites More sharing options...
lionbull Posted April 6, 2015 Report Share Posted April 6, 2015 Go for more cruise ignition and size the turbo correctly for spool. Link to comment Share on other sites More sharing options...
