ticktown Posted December 29, 2014 Report Share Posted December 29, 2014 Hello: I have an '86 Starion with hydraulic lifters. I'm finally getting around to eliminating my jet valves with the kit I got from Dad. I have the rocker cover off. Do I have to remove the rocker assembly or is there a way to get the jet valves out with the rockers still in? Many thanks. Link to comment Share on other sites More sharing options...
vbrad511 Posted December 30, 2014 Report Share Posted December 30, 2014 (edited) If I remember right, you just need a deep socket....maybe 14mm. Valvetrain can stay in place. Edited December 30, 2014 by vbrad511 Link to comment Share on other sites More sharing options...
TexasQuest Posted December 30, 2014 Report Share Posted December 30, 2014 I believe you do have to remove it. They are under the rocker arms. Link to comment Share on other sites More sharing options...
ucw458 Posted December 30, 2014 Report Share Posted December 30, 2014 You at least have to remove the adjuster screw in the rocker. If you remove the whole assembly you can take the intake rockers off and cut off the tab for the jet valves. Slightly less weight on the rockers means the springs have less weight to move. The jet valves had a closing spring that helped the main spring. Reduced rocker arm weight = more stable at higher rpm. Link to comment Share on other sites More sharing options...
TexasQuest Posted December 30, 2014 Report Share Posted December 30, 2014 Instead of cutting them, is there a non jet valve rocker arm we can use? Link to comment Share on other sites More sharing options...
Squrlsquash Posted December 30, 2014 Report Share Posted December 30, 2014 Yes, one of my rocker sets have the lifter screws, and the other does not.Has casting marks, not been cut off. Link to comment Share on other sites More sharing options...
ucw458 Posted December 30, 2014 Report Share Posted December 30, 2014 Instead of cutting them, is there a non jet valve rocker arm we can use? Yes. Just use the 4 more exhaust side rockers. Or get some from a non jet valve head like a caravan head. Cutting them wont hurt the rocker. It's safe as long as you don't remove it by breaking it off like hitting it with a hammer. Link to comment Share on other sites More sharing options...
ticktown Posted December 30, 2014 Author Report Share Posted December 30, 2014 The manual says use special tool MD998443 to hold the lash adjusters in place (so not to spill the diesel fuel!?) when removing the rockers. I don't have this tool. Alternatives? Link to comment Share on other sites More sharing options...
ucw458 Posted December 30, 2014 Report Share Posted December 30, 2014 You can make those tools from some banding or paper clips. Or just loosen all the bolts and remove the lash adjusters one at a time before pulling the assembly off. Put them in an egg carton or ice tray to keep them organized so you can put each one back in the hole it came from. Link to comment Share on other sites More sharing options...
ticktown Posted December 30, 2014 Author Report Share Posted December 30, 2014 thanks for the tips Link to comment Share on other sites More sharing options...
ticktown Posted December 30, 2014 Author Report Share Posted December 30, 2014 http://i1332.photobucket.com/albums/w607/cavicke75/IMG_20141230_163645905_zps1f38f8e8.jpg Link to comment Share on other sites More sharing options...
TexasQuest Posted January 2, 2015 Report Share Posted January 2, 2015 Would these suffice? http://www.ebay.com/itm/Mitsubishi-Roller-Rocker-Arms-for-4G54-engine-Magna-Pajero-TR-TS-/251772987687?pt=AU_Car_Parts_Accessories&hash=item3a9ed6e927 Link to comment Share on other sites More sharing options...
vbrad511 Posted January 2, 2015 Report Share Posted January 2, 2015 Cut the fingers off a pair of rubber gloves and slip them over the rocker arms. Link to comment Share on other sites More sharing options...
