shift1313 Posted March 4, 2013 Report Share Posted March 4, 2013 Well it's been almost 10 years with a 1600sqft garage and its time to step down to a normal 2 car so a lot of the random parts i've held on to need to go. There are some things I will ship off individually but in general it would be great if someone would just take it all:) There is a bit more but here is the pile. http://farm9.staticflickr.com/8510/8525196043_c68b736696_c.jpg First off the individual stuff Ill ship off if someone wants it. Parts distributor from a Non-IC car. I used some of the parts on this CAS setup I was making. I took a CAS(optical pickup) off another mits, modified the housing so it had an oring setup to fit in the stock head. The gear needs a set screw to locate it on the cam gear. The idea was an oem looking setup for distributorless ignition. $25+shipping. there are some other parts with the dist. including the vac advance unit. i can take more pics if needed.http://farm9.staticflickr.com/8374/8525189541_2e3e56cb9c_c.jpghttp://farm9.staticflickr.com/8372/8526305218_04e369482f_c.jpg It still needs work but is a fun project. Next is an unmolested 86(i think) air can. I had planned on using it on my 84 but it wasnt a bolt in swap. $15+shipping http://farm9.staticflickr.com/8377/8525180141_16257cc04c_c.jpg Id rather not ship(cause rotors and calipers are heavy) but can if someone needs them. Stock brakes from my 84 with rotors. Rotors need to be turned. Brakes worked but im sure could use a rebuild. Comes with the splash shield, calipers, rotors, rubber lines(i wouldnt use) etc. $50 Another thing I will ship but would rather not because of cost. Crank that had spun rods. Needs turned. Free for shipping if someone wants it.http://farm9.staticflickr.com/8089/8526292808_74bf93eca9_c.jpg Now to all the random junk. Some if it is probably trash and will probably end up there but i think there is some usable stuff. Box #1. has some rad hoses in it, an isc servo from my 84. Worked but the rubber boot is torn. that was years ago. There is a Tstat/water neck off a DSM 2.0. I was going to use it for an MPI i was working on since you can bolt it on and it has a filler on it. http://farm9.staticflickr.com/8098/8525192183_b80c294918_c.jpg Box#1 had a steering wheel wrap/cover, all the oem vac lines i deleted, a heat shield that came from under the turbo i think and some other random bits like a bosch starter in pieces... http://farm9.staticflickr.com/8234/8526307484_273abeedb0_c.jpg Box#3 more random stuff. I t hink im going to keep the fan and AC components cause i might put those back on at some point. I think i have the ABS stuff in that box if someone needs it and some other components. heat shields, fan clutch, some emissions stuff.. http://farm9.staticflickr.com/8103/8525193501_725d622b4a_c.jpg 5 speed tranny with bad 5th. maybe good for parts, maybe rebuild 5th. $50 to a good home. http://farm9.staticflickr.com/8228/8525186545_dbc50de949_c.jpg 5 lug front hubs and rotors(rotors i think are trash, super rusted). I also have some crown vic interceptor rotors i was going to mock up an OS widebody brake kit with. Good but could be turned. Free to a good home. http://farm9.staticflickr.com/8097/8525188829_a5148695d7_c.jpg Ive got a stock exhaust form turbo to muffler(no muffler back) thats been gutted. Its still boxed up. Shipping would probably be nuts. $40+shipping. I also have some ECUs, knock boxes and some other electronic parts from a few different year flattys. I think 85 auto and 85 5 speed ecus. Ill have to look. Some more free stuff that id prefer not to ship again. My brother was a mitsu mechanic for 20 years and when the dealer would revolve stock and pitch anything that was a few years old, him and the other mechanics would just stock pile it. Ive got boxes of oem mits seals, gaskets etc for various cars. lots with part numbers on them. Boxes of hardware, thinks like motor mount bolts, under hood bolts, door push fasterners, again for mits stuff. Also some mechanical components and eletronics. There are some toyota spindles from im guessing a small car, transmission shafts, bearings, seals, electronic relays, wires, vac lines and so on. Over the years i have used this stuff for many things. OEM mits hardware has been the same for awhile. If someone has a few mits cars or wants to go through and figure out what the part numbers are for and sell the stuff they could. http://farm9.staticflickr.com/8091/8525185315_ebe258aafe_c.jpg http://farm9.staticflickr.com/8383/8526297412_c6ef93db72_c.jpg http://farm9.staticflickr.com/8241/8525184437_cec2a9bc40_c.jpg http://farm9.staticflickr.com/8103/8525182105_a85b172ec9_c.jpg ive also got a 7" front with a 205 tire on it that i was using for brake mockups. rim has some curb rash, not sure if its straight. Again free to a good home. Might be good for a spare or mock ups for something, painting i dont know. http://farm9.staticflickr.com/8510/8526291956_6760537f99_c.jpg So obviously thats a lot of random stuff that I just won't have the room for. I was a little shocked how much there was when i pulled it out, not counting the spares im keeping like motors and so on. So what I would really love is if someone was in the area or swinging by and wants the stuff. With the exception of the ECUs/knock boxes i need to list if someone wants to take it all you can have it for free. It's worth it to me to get it all out in one shot. Im located in blacksburg, VA 24060 and I can get you more pics/info whatever you need on anything. It wasnt worth pulling everything out of the boxes to take pics but i can make a list if someone thinks they would take it all. Quote Link to comment Share on other sites More sharing options...
shift1313 Posted March 4, 2013 Author Report Share Posted March 4, 2013 oh yeah i have a 12a with no compressor housing on it. ran fine in my car but i think has a little shaft play. $25+shipping or free with the pile. i also have various speakers and amps. some 6x9 100w stuff, some 90w door subs and so on. free with the pile:) Quote Link to comment Share on other sites More sharing options...
JohnnyWadd Posted March 4, 2013 Report Share Posted March 4, 2013 ill take the hubs Quote Link to comment Share on other sites More sharing options...
speedyquest Posted March 4, 2013 Report Share Posted March 4, 2013 I'll take the 12a, can I get a picture of it? I'll send you a message with my info Quote Link to comment Share on other sites More sharing options...
mr-starion Posted March 5, 2013 Report Share Posted March 5, 2013 Ill take all fasteners and clips. Doing a resto and this can really help Quote Link to comment Share on other sites More sharing options...
mr-starion Posted March 5, 2013 Report Share Posted March 5, 2013 Actually ill take what i mentioned above and wtv you have thats brand new for our cars in those boxes Quote Link to comment Share on other sites More sharing options...
shift1313 Posted March 5, 2013 Author Report Share Posted March 5, 2013 Ill take all fasteners and clips. Doing a resto and this can really helpActually ill take what i mentioned above and wtv you have thats brand new for our cars in those boxes I don't have anything new. All parts are used. Also I don't know that i have clips or fasteners directly related to the starion. The box of hardware is just a mitsu thing. All the hardware and clips from my car are safely packed away and organized and not in this mess:) My car is complete minus the ac and abs so this isnt a box of stuff from a part out, sorry Just to clarify, There are a few bigger items that are for sale, I dont want to start picking through all this stuff and shipping out small items. I dont think its worth the time or money on either end. The bigger stuff like the airbox, hubs etc are parts that could easily be used. The rest is just random used parts. When i go through and try and catalog whats in the boxes(maybe this saturday) i can let you know if i find hardware/clips etc but i doubt there will be much/enough to justify paying shipping on them. i could be wrong though. JohnnyWadd, hubs are yours if you want them. PM your zip and ill get you a shipping estimate. I think they will fit in a large flat rate box so it should be around $15 hopefully. Speedy, i responded to your PM, ill snap a pic later for you of the turbo. Quote Link to comment Share on other sites More sharing options...
le fou Posted March 5, 2013 Report Share Posted March 5, 2013 can you ship to switzerland ? I'm interrested by the air box ;-) Quote Link to comment Share on other sites More sharing options...
mr-starion Posted March 5, 2013 Report Share Posted March 5, 2013 Ok:( Quote Link to comment Share on other sites More sharing options...
shift1313 Posted March 6, 2013 Author Report Share Posted March 6, 2013 can you ship to switzerland ? I'm interrested by the air box ;-) If you pay shipping i dont see why not. I can't imagine shipping would be cheap though. if you want to PM me your info ill try and get a quote for you. Quote Link to comment Share on other sites More sharing options...
sqall12001 Posted March 6, 2013 Report Share Posted March 6, 2013 On the optical dist, it works, except for the set screw? Do I need to align anything or just snug gear to top and tighten set screw?If it works and thats all I'll take it (I can pay friday) along with anything small (interior screws, random stuff? that will go into a flat rate box maybe?My zip is 71241 -Nick Quote Link to comment Share on other sites More sharing options...
shift1313 Posted March 6, 2013 Author Report Share Posted March 6, 2013 On the optical dist, it works, except for the set screw? Do I need to align anything or just snug gear to top and tighten set screw?If it works and thats all I'll take it (I can pay friday) along with anything small (interior screws, random stuff? that will go into a flat rate box maybe?My zip is 71241 -Nick No nick its a project. I built a megasquirt for this car years ago and wanted to control the ignition as well. Instead of running the ford edis stuff i was looking for other options. This optical pickup will not work in place of the OEM dizzy. The idea was to have a signal for an aftermarket ECU. Quote Link to comment Share on other sites More sharing options...
sqall12001 Posted March 7, 2013 Report Share Posted March 7, 2013 I mean is the new dizzy complete. I am going to be running a megasquirt to a MSD DIS-4, I can run sequential ignition if I have a Cam signal for cyl 1 recognition. I will be using a Crank VR for my other sensor. I wanted to make sure I didn't need anything other then a set screw for this to work. I need a nice compact clean dizzy cover or replacement so I have as much room as I can get when I build my MPI manifold. Thx,-NickNo nick its a project. I built a megasquirt for this car years ago and wanted to control the ignition as well. Instead of running the ford edis stuff i was looking for other options. This optical pickup will not work in place of the OEM dizzy. The idea was to have a signal for an aftermarket ECU. Quote Link to comment Share on other sites More sharing options...
shift1313 Posted March 7, 2013 Author Report Share Posted March 7, 2013 (edited) Nope. Its not a new distributor. Its a CAS off some other mits that i started to hack up to fit the starion head. I took the main shaft from a stock distributor and modified the CAS housing to hold the bearings/shaft and also have an oring grove to seal to our heads. The make the CAS housing fit it will need a small bit more modification to the slots for the head stud. The slot is slightly off for where it needs to be. The shaft needs to be drilled for a roll pin for the gear as well. There is a hole in the shaft(since its the OEM dist shaft) but its not in the right spot. I marked it but never drilled it. I believe this CAS originally came off a 4g63 eclispse but don't know for sure. here is a good reference about CAS and using it on other cars with MS ecu's. I originally(and i might build one again or keep this one if you/nobody wants it) was going to do an MS/mpi car as well and clearing the room there was big. I think its a great option for MS cars but its not a direct bolt on deal for our cars because of the distance to the cam. Another consideration might be some bracing for the shaft. The stock Dist has casting all the way to the gear, this setup now is a free hanging shaft. One thing i thought about was welding a shaft onto the housing with a bushing in the end. So as I said its not a direct bolt on deal just yet but ive already modified a good bit of it on a lathe to accept the bearing from the starion Dizzy and an oring to seal to the head. http://forums.turbob...ad.php?t=224740 Here are a few more pics on a scrap head. http://i268.photobucket.com/albums/jj39/shift1313/Starion/PB250025.jpg http://i268.photobucket.com/albums/jj39/shift1313/Starion/PB250023.jpg http://i268.photobucket.com/albums/jj39/shift1313/Starion/PB250021.jpg http://i268.photobucket.com/albums/jj39/shift1313/Starion/PB250020.jpg http://i268.photobucket.com/albums/jj39/shift1313/Starion/CasDizzy3.jpg http://i268.photobucket.com/albums/jj39/shift1313/Starion/CasDizzy2.jpg Edited March 7, 2013 by shift1313 Quote Link to comment Share on other sites More sharing options...
shift1313 Posted March 7, 2013 Author Report Share Posted March 7, 2013 i can take the top off to show you the inside of it if you want. I do not have the connector that plugs into this either. Well i might have one somewhere but i think its easy enough to find. Let me know Quote Link to comment Share on other sites More sharing options...
sqall12001 Posted March 7, 2013 Report Share Posted March 7, 2013 I knew it wasn't "New" i meant more new to me. I was hoping it just needed a roll pin. I can fab, but don't have access to any machining tools unfortunately. -Nick Quote Link to comment Share on other sites More sharing options...
shift1313 Posted March 7, 2013 Author Report Share Posted March 7, 2013 I knew it wasn't "New" i meant more new to me. I was hoping it just needed a roll pin. I can fab, but don't have access to any machining tools unfortunately. -Nick I dont think its more than drilling the shaft and some filling of the slot to mount the thing but i understand. I dont think ive seen another CAS modded for a starion so unfortunately its a SOLO type thing. Quote Link to comment Share on other sites More sharing options...
tux Posted April 24, 2013 Report Share Posted April 24, 2013 if you have the door push pin hardware i would LOVE to buy some . My door panels are missing a few ! Quote Link to comment Share on other sites More sharing options...
