boostinmini Posted December 16, 2012 Report Share Posted December 16, 2012 no need for more starion tps that are not avail https://picasaweb.google.com/lh/photo/DzAvfYoVv7gq3591ZMk7RJQw9aEIlrqb0QuNMJhGrfQ?feat=directlink Link to comment Share on other sites More sharing options...
toofast Posted December 16, 2012 Report Share Posted December 16, 2012 So the question is ,how much did that cost and do you have a part # and what is needed to make the swap if someone is in need of one? Link to comment Share on other sites More sharing options...
TexasQuest Posted December 16, 2012 Report Share Posted December 16, 2012 Yes please describe what you did. Link to comment Share on other sites More sharing options...
boostinmini Posted December 16, 2012 Author Report Share Posted December 16, 2012 well that plate is custom made adapter to use a different tps aka this one for example is a mazda one Link to comment Share on other sites More sharing options...
Scotty Dont Posted December 16, 2012 Report Share Posted December 16, 2012 Does it even work properly? Just because it fits in the location doesn't mean it will have the proper resistance for a given throttle possition. Link to comment Share on other sites More sharing options...
boostinmini Posted December 16, 2012 Author Report Share Posted December 16, 2012 well i am running megasquirt so it does not matter but i comparred the values to the starion on when i tested it an it was spot on with the starion one as per the specs in the fsm Link to comment Share on other sites More sharing options...
Crazy Quest Posted December 16, 2012 Report Share Posted December 16, 2012 I also am running MS and am wondering what you have noticed different with this? More accurate? Faster Response? Link to comment Share on other sites More sharing options...
88-cnqst-tsi Posted December 16, 2012 Report Share Posted December 16, 2012 could you give a detailed explination on how to make it please Link to comment Share on other sites More sharing options...
boostinmini Posted December 16, 2012 Author Report Share Posted December 16, 2012 I also am running MS and am wondering what you have noticed different with this? More accurate? Faster Response? if your tps fails like mine did u will learn it is almost impossible to find a working one new or used, basically just an other option as a replacement, i decided to think outside the box after 4 months of searching for a tps Link to comment Share on other sites More sharing options...
88-cnqst-tsi Posted December 16, 2012 Report Share Posted December 16, 2012 if your tps fails like mine did u will learn it is almost impossible to find a working one new or used, basically just an other option as a replacement, i decided to think outside the box after 4 months of searching for a tpslol that took long for you i decided to try to fix mine after i found out that a new one is 450+shipping from where ever in a small town of japan probably Link to comment Share on other sites More sharing options...
boostinmini Posted December 16, 2012 Author Report Share Posted December 16, 2012 mine actually seized solid i tried to fix it but to far gone Link to comment Share on other sites More sharing options...
Crazy Quest Posted December 16, 2012 Report Share Posted December 16, 2012 Does it bolt right up with the plates you made? Have you wired it in and tested it yet? Link to comment Share on other sites More sharing options...
ucw458 Posted December 16, 2012 Report Share Posted December 16, 2012 The SQ TPS IS still available. You just have to know where to look. 89-90 Hyundi Sonata 2.4 uses the same TPS sensor just with a male plug instead of a female like the SQ. Swap the plugs and it's a perfect fit. RockAuto has them for $78. Standard Motor Products part #TH315Wells part #TPS451Mitsu part #ACA-TPS035 http://d3d71ba2asa5oz.cloudfront.net/82000081/images/tps035.jpg Link to comment Share on other sites More sharing options...
Scotty Dont Posted December 16, 2012 Report Share Posted December 16, 2012 Rock auto nor anywhere else I looked ever had the sonata tps. Luckily I have a few in good condition now but no g54b to put them on. Link to comment Share on other sites More sharing options...
aknorthstar Posted December 16, 2012 Report Share Posted December 16, 2012 Well rock auto sells the stock TPS but does anyone want to pay 176.89...... STANDARD MOTOR PRODUCTS Part # TH249 Link to comment Share on other sites More sharing options...
Komeuppance Posted December 16, 2012 Report Share Posted December 16, 2012 Haha, it's just a plate to allow the new sensor to bolt up, not difficult to make one yourself at all. Great job Mike, looks good. Almost all TPS's are going to be a 5v sensor, and almost all throttle plates are going to be 0 to 90 degrees, so in theory they'll work just fine as long as you can get the idle voltage set properly. I've used a Ford TPS that didn't need an adapter plate. Forgot what it was off of though. -Robert Link to comment Share on other sites More sharing options...
ucw458 Posted December 16, 2012 Report Share Posted December 16, 2012 Rock auto nor anywhere else I looked ever had the sonata tps. Luckily I have a few in good condition now but no g54b to put them on. You're right. I thought they were available but I can't find one either. Link to comment Share on other sites More sharing options...
RF600 Posted December 16, 2012 Report Share Posted December 16, 2012 Haha, it's just a plate to allow the new sensor to bolt up, not difficult to make one yourself at all. Great job Mike, looks good. Almost all TPS's are going to be a 5v sensor, and almost all throttle plates are going to be 0 to 90 degrees, so in theory they'll work just fine as long as you can get the idle voltage set properly. I've used a Ford TPS that didn't need an adapter plate. Forgot what it was off of though. -Robert Remember which Ford grasshopper. I'm curious. Link to comment Share on other sites More sharing options...
TexasQuest Posted December 16, 2012 Report Share Posted December 16, 2012 well that plate is custom made adapter to use a different tps aka this one for example is a mazda oneWhat mazda engine is that tps from? Link to comment Share on other sites More sharing options...
ucw458 Posted December 16, 2012 Report Share Posted December 16, 2012 86 starion on RockAuto still has a listing for TPS as a Airtex/Wells replacement. There catalog shows no TPS available for any other year SQ whether it be Mitsu, Dodge or Chrysler. It's $158 and I just got off the phone with RockAuto and their computer shows airtex has them in their warehouse. It would be shipped directly from Airtex. Link to comment Share on other sites More sharing options...
aknorthstar Posted December 16, 2012 Report Share Posted December 16, 2012 It showed up this morning when i checked ...now nothing. Link to comment Share on other sites More sharing options...
aknorthstar Posted December 19, 2012 Report Share Posted December 19, 2012 Napa seems to have them in stock echlin# CRB 216735 $210 Link to comment Share on other sites More sharing options...
boostinmini Posted December 20, 2012 Author Report Share Posted December 20, 2012 yeah 210 seems pretty steep compared to this one that so far has been working great, now i got more features to play with in the megasquirt Link to comment Share on other sites More sharing options...
boostinmini Posted January 18, 2013 Author Report Share Posted January 18, 2013 For any one thats interested I have made a few for sale http://www.starquestclub.com/forum/index.php?showtopic=135135 If you are interested please pm me. thanks Link to comment Share on other sites More sharing options...
