speedbling Posted March 9, 2012 Report Share Posted March 9, 2012 keep me posted i feel im having a similar problem. the car is not a daily driver but i hope it to be. Link to comment Share on other sites More sharing options...
SnohoQuest Posted March 12, 2012 Author Report Share Posted March 12, 2012 Alright well.... My freshly cleaned injectors are back and the car no longer runs rich! the smell is gone!! And is idling a little more smoothly. However... the hesitation still exists. i also had my fuel pressure checked, and my vac adv was also checked. So.. now im going to try a full tune up, cap rotor wires coil oil plugs and fuel filter. just to see if the problem still arises... Link to comment Share on other sites More sharing options...
Technology Posted March 13, 2012 Report Share Posted March 13, 2012 just use normal, el cheapo wires, they are fine, no need for uber expensive, bright, colorful, thick wires that do the exact same thing. Only replace the cap and rotor if they are cracked or broken. Your injectors could be cleaner, but might still be bad. Unplug the secondary and see if the problem is the same. Also, that leads me to injector clips. Often overlooked, but very important. New ones would be a good idea, and they're cheap. Another idea is to check that you aren't overboosting. make sure the vacuum line is connected to the wastegate and not leaking. Then check for boost leaks in the intercooler pipes. Link to comment Share on other sites More sharing options...
SnohoQuest Posted March 14, 2012 Author Report Share Posted March 14, 2012 Ohhhhh dang good point. I havent thought of either of those yet definitely gonna take a look at both Link to comment Share on other sites More sharing options...
Caliber308 Posted March 14, 2012 Report Share Posted March 14, 2012 (edited) just use normal, el cheapo wires, they are fine, no need for uber expensive, bright, colorful, thick wires that do the exact same thing. Tech, You are kidding. I have used Mallory, Accel and Stock Spark plug Wires. Now I use Magnacor 8.5mm. There is a world of difference between them, and the other three Spark Plug wire sets. Magnacor uses Stainless Steel wire wound 200 turns per inch with a heat resistance of 1000 degrees. I have had problems with Mallory Spark Plug wires. I purchased a brand new set of 7mm Mallory Spark Plug Wires for my Starion. Three months later I had a miss in my engine. Ended up checking the entire system out, come to FINALLY find out it was a bad spark plug wire. Bill Edited March 14, 2012 by Caliber308 Link to comment Share on other sites More sharing options...
Indiana Posted March 14, 2012 Report Share Posted March 14, 2012 Hesitation can be the TPS dirty or an injector clip. Even new clips don't last unless you put dielectic grease on them. Use your volt meter on the TPS wires and have someone very slowly push the gas pedal down and your needle on the gauge should sweep evenly, no dead spots or jerks. If the cam inside is cracked or broken off it will hesitate in a bad way. If this is under boost hesitation not idling, those plug wires can't just be laying there they put those plastic insulators on there for a reason.http://www.b2600turbo.com/images/plugwiring02.jpg NGK plug wires, part #ME51 are less than $20 Link to comment Share on other sites More sharing options...
SnohoQuest Posted April 5, 2012 Author Report Share Posted April 5, 2012 tested my TPS reset skills again and found that no matter how much i move my TPS the voltage never changes? i would expect to see a least a little bit of change, is it supposed to be locked on at .48v and not have any movement? i know the book says that's perfect but i would've though i could at least get some differentiation.. Link to comment Share on other sites More sharing options...
The Rabbit1 Posted April 5, 2012 Report Share Posted April 5, 2012 tested my TPS reset skills again and found that no matter how much i move my TPS the voltage never changes? i would expect to see a least a little bit of change, is it supposed to be locked on at .48v and not have any movement? i know the book says that's perfect but i would've though i could at least get some differentiation..TPS is shot, you can imagine how I know. I bet the contacts inside are completely broke off. Link to comment Share on other sites More sharing options...
Indiana Posted April 6, 2012 Report Share Posted April 6, 2012 You're using the wrong wires or you are doing it backwards. I doubt its bad. Take it off, let it hand in the air and put the test leads on and move the lever with your finger. That plastic cam might be broken. Link to comment Share on other sites More sharing options...
SnohoQuest Posted April 6, 2012 Author Report Share Posted April 6, 2012 Took it off and the numbers changed when i did it by hand, i must've done it wrong. Link to comment Share on other sites More sharing options...
