87quest_stv Posted May 11, 2012 Author Report Share Posted May 11, 2012 I'm going to have a bunch of questions Link to comment Share on other sites More sharing options...
87quest_stv Posted May 11, 2012 Author Report Share Posted May 11, 2012 I was reading in one of these 2jz swap posts about someone's harness connectors exploding when you touch them. My are cracked as well. I saw someone else post a link to a place where I can get some new connectors. But For the life of me I can't find that post., Link to comment Share on other sites More sharing options...
BOHO Posted May 11, 2012 Report Share Posted May 11, 2012 I got mine from here....but he isn't showing much on the site...might have to e-mail him. http://www.tweakdperformance.com/index2.html Link to comment Share on other sites More sharing options...
87quest_stv Posted May 11, 2012 Author Report Share Posted May 11, 2012 (edited) Thanks for that. After closer examining the wiring harness it seems the cut part of the harness was the E10 connector. and it looks like the other E9 connectors were spliced and pinned differently.I found a wiring diagram online which has the pin and color coded wiring which some of the wires on the E9 connector are where they are suppose to be but other wire colors don't match the pin. Gonna need as much help as possible with this. http://www.getyasumminimotos.com/Conquest/ecuwires.jpghttp://www.getyasumminimotos.com/Conquest/ecuwires2.jpghttp://www.getyasumminimotos.com/Conquest/ecuwires3.jpghttp://www.getyasumminimotos.com/Conquest/ecuwires4.jpg The link that has the pin out is here. All the way at the bottom for the 2jz connectorhttp://www.supras.nl...id=34&Itemid=50 Edited May 11, 2012 by 87quest_stv Link to comment Share on other sites More sharing options...
RobH Posted May 11, 2012 Report Share Posted May 11, 2012 (edited) did you get the i think its called the E-10 connector (40pin) that plugs into the ecuyou will need it for a few wires and in the one pic of the cut harness i think thats not the E-10 thats cut thats the body harness ( My harness was cut the same way yours is ) but mine had the E-10 connector in the ecu the E-10 end would still be on the car but like i said you will need the E-10 connector if you need me to i can get some close up pics of my harness to try and figure out the pins that were swapped on yours Edited May 11, 2012 by RobH Link to comment Share on other sites More sharing options...
BOHO Posted May 11, 2012 Report Share Posted May 11, 2012 ^ yes... The plug your missing on the ecu is where you are going to put your 12v's and grounds. "IN" not "OUT" Link to comment Share on other sites More sharing options...
87quest_stv Posted May 11, 2012 Author Report Share Posted May 11, 2012 (edited) Ahh OK So I only need the E10 to connect power and grounds into the ECU. Gotya. Robh yeah if you can email me a couple close up pics I'd appreciate it. I'll PM you email I gotta get a hold of vettkiller to see if he has anymore mounts as well Edited May 11, 2012 by 87quest_stv Link to comment Share on other sites More sharing options...
87quest_stv Posted May 11, 2012 Author Report Share Posted May 11, 2012 Goal is to get the engine in the car. and running so I can check for any problems. Then pull it out again and finish what I need to. Link to comment Share on other sites More sharing options...
87quest_stv Posted May 14, 2012 Author Report Share Posted May 14, 2012 wondering if anyone has any input on this turbo manifold?http://www.ebay.com/itm/Toyota-Supra-Turbo-Manifold-2JZ-GTE-2JZGTE-MKIV-93-98-/140493094490?pt=Motors_Car_Truck_Parts_Accessories&hash=item20b60a7e5a&vxp=mtr Link to comment Share on other sites More sharing options...
RobH Posted May 14, 2012 Report Share Posted May 14, 2012 i cant help ya thereim going to be going single turbo sooni thought i would get my swap done and all the bugs worked out and put a couple thousand miles on it firstand i now have almost 5k miles on my swap and havent even given any thought to the single turbo yetbut im sure it wont be long and ill get the itch for it Link to comment Share on other sites More sharing options...
87quest_stv Posted May 14, 2012 Author Report Share Posted May 14, 2012 I was just thinking, the engine is out. Might as well go single now. rather than later. I've heard the stock twins can't handle more than 14lbs due to the ceramic turbine blades. I dunno. Just getting ideas. Link to comment Share on other sites More sharing options...
87quest_stv Posted May 14, 2012 Author Report Share Posted May 14, 2012 Picked up my cam seals, and crank seal today. I also ordered my waterpump, hydraulic tensioner, and rear main seal from the toyota dealer today.I got the water pump, hydraulic tensioner, 2 cam seals, front crank seal, and rear main seal for $232 at the yota dealer. I was happy. picked up a new timing belt from autozone. for 20 bucks, it's a duralast and made in Italy. so good quality belt there for good price. picked up a timing belt tensioner roller for 23 bucks. will get my serpentine belt from driftmotion and the stuff for my tranny I need as well. Anyone have a good method for breaking that crank bolt loose without tearing stuff up? Link to comment Share on other sites More sharing options...
RobH Posted May 14, 2012 Report Share Posted May 14, 2012 impact !!! if you dont have one then you will have to try to lock the flywheel against the bellhousing with a good sized screwdriver threw the starer holemine was not all that tightthe good thing is even if you messed something up which you shouldnt you wont be using the bellhousing or flywheel anyways Link to comment Share on other sites More sharing options...
87quest_stv Posted May 15, 2012 Author Report Share Posted May 15, 2012 Yeah, I've got an impact, hope mine isn't super tight.On another note , when you get a chance, can you email me the pics of your ecu pin out? I PM'd you my email Link to comment Share on other sites More sharing options...
RobH Posted May 15, 2012 Report Share Posted May 15, 2012 yup i will as soon as i can very limited on use of my feft hand right now got stiches out of it today and my cut split back open ill hook you up before your rdy for it Link to comment Share on other sites More sharing options...
87quest_stv Posted May 15, 2012 Author Report Share Posted May 15, 2012 Ahh that's right. Forgot you sliced your hand all to pieces. Link to comment Share on other sites More sharing options...
Shaggy_TSi Posted May 15, 2012 Report Share Posted May 15, 2012 Not to thread jack but, even with r154 just go with a normal 2jz pilot bearing? (6 speed 2jz) Link to comment Share on other sites More sharing options...
87quest_stv Posted May 15, 2012 Author Report Share Posted May 15, 2012 Hey shaggy. I have relatives in barranquitas and manati. I was just in PR back in March. Was hoping to see a few starquests but never did. Link to comment Share on other sites More sharing options...
87quest_stv Posted May 16, 2012 Author Report Share Posted May 16, 2012 Picked up my waterpump, rear main seal, and hydraulic tensioner, and serpentine belt today. have my new radiator coming Friday. Now I just need some nice weather. Been raining all over the place lately Link to comment Share on other sites More sharing options...
BOHO Posted May 16, 2012 Report Share Posted May 16, 2012 I ordered some parts for my jeep today....I need to get it sold so I can join the single turbo club... Link to comment Share on other sites More sharing options...
87quest_stv Posted May 16, 2012 Author Report Share Posted May 16, 2012 After doing some more research on this wiring harness, it looks like this harness doesn't even have the correct E9 80 pin connector on it. Nor did the engine come with an ignitor box.I'm assuming I need an ignitor box to get the engine running? Link to comment Share on other sites More sharing options...
87quest_stv Posted May 16, 2012 Author Report Share Posted May 16, 2012 I found the toyota part numbers for the E9 connector and E10 connector. Also was able to order them through my toyota dealer for a reasonable price E9 - 90980-11214 - $22E10 - 90980-11215 - $15 Link to comment Share on other sites More sharing options...
BOHO Posted May 16, 2012 Report Share Posted May 16, 2012 I don't know if this is the right one but good price. http://www.ebay.com/itm/Toyota-DIS-6-Ignitor-2JZ-GTE-Digital-spark-7M-GTE-2JZ-GE-Supra-MK4-TT-and-NA-use-/140616563415?pt=Motors_Car_Truck_Parts_Accessories&hash=item20bd667ad7&vxp=mtr Link to comment Share on other sites More sharing options...
87quest_stv Posted May 16, 2012 Author Report Share Posted May 16, 2012 Thanks for that. Well after digging into this harness I decided to pick up a new one. Well new used. Got one locally from a guy off craigslist. Good shape with all the connectors. Nothing broken or brittle. Link to comment Share on other sites More sharing options...
87quest_stv Posted May 16, 2012 Author Report Share Posted May 16, 2012 Ordered my motor mounts from vettekiller today. Should have those by end of next week hopefully. another rained out day today as well. Couldn't get much done Link to comment Share on other sites More sharing options...
