87quest_stv Posted May 7, 2012 Author Report Share Posted May 7, 2012 Need some help. Found a 2jzgte engine in real good shape. The seller said the harness was cut and sent me some pics. Can anyone tell me if this is important or not? http://www.getyasumminimotos.com/Conquest/005.JPG Link to comment Share on other sites More sharing options...
BOHO Posted May 8, 2012 Report Share Posted May 8, 2012 I "think" that is the body plug that you would have to splice into anyways for gauges and 12v to systems. As long as the ecu plugs and then sensor / ignitor plugs are intact you should be good. Check to see which plug it is. If its the body plug it doesn't matter because you can't plug it into anything anyways...lol. Link to comment Share on other sites More sharing options...
87quest_stv Posted May 8, 2012 Author Report Share Posted May 8, 2012 Yes he said the other connectors were for the ecu. Anyhow. I've decided to go with the 2jzgte off the bat. I've been doing a lot of searching and biding my time for the right deal to come up. I found it.I picked up the R154 tranny for 350. and the 2jzgte for 1700 shipped. just need the bellhousing, flywheel and clutch kit which I think I can get for another 400-500 so i'll have about 2700 2800 in the thing initially. speaking of needing a flywheel. will the 7mgte flywheel work? or has to be a 1jz flywheel Link to comment Share on other sites More sharing options...
87quest_stv Posted May 8, 2012 Author Report Share Posted May 8, 2012 Here's the 2j I picked up http://www.getyasumminimotos.com/Conquest/2JZgte.JPG Link to comment Share on other sites More sharing options...
BOHO Posted May 8, 2012 Report Share Posted May 8, 2012 It has to be 1jz flywheel. Cheapest I have found is Competition clutch flywheel on ebay. 282 shipped for a 14lb one. Link to comment Share on other sites More sharing options...
87quest_stv Posted May 8, 2012 Author Report Share Posted May 8, 2012 I'm thinking of doing something like this.http://www.ebay.com/itm/F1-STAGE-4-CLUTCH-KIT-RACING-FLYWHEEL-JDM-SUPRA-SOARER-SC300-1JZGTE-2JZGTE-R154-/160716628585?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item256b752269 Link to comment Share on other sites More sharing options...
BOHO Posted May 8, 2012 Report Share Posted May 8, 2012 Some say they are the same thing...I'm not willing to take the risk. But let me know if it works well. Link to comment Share on other sites More sharing options...
87quest_stv Posted May 8, 2012 Author Report Share Posted May 8, 2012 What's this i've read about the waterpump to US spec housing? I'm looking to replace the waterpump when i get the engine. Can I buy one for a 2jzgte US engine and be ok? Link to comment Share on other sites More sharing options...
BOHO Posted May 8, 2012 Report Share Posted May 8, 2012 Yeah...The JDM spec ones ran a hydraulic pump for their fans....Driftmotion sells the one you need for a decent price. Link to comment Share on other sites More sharing options...
D-VO Posted May 10, 2012 Report Share Posted May 10, 2012 I like how there's always an active JZ swap going on. I hope to be at this point next year Doing all my legwork/research now. Link to comment Share on other sites More sharing options...
RobH Posted May 10, 2012 Report Share Posted May 10, 2012 yup you need thishttp://store.driftmotion.com/static/i-2jz-gte1jz-gtewaterpump.php along with thesehttp://store.driftmotion.com/static/i-jzpulleykitv206061aluminum.php i had to do the same thing Link to comment Share on other sites More sharing options...
RobH Posted May 10, 2012 Report Share Posted May 10, 2012 oh this will help cut some time also http://store.driftmotion.com/static/i-starionconquest1jz2jzpshose.php Link to comment Share on other sites More sharing options...
RobH Posted May 10, 2012 Report Share Posted May 10, 2012 when i did my swap i replaced timing belt,water pump,tensioner,tensioner pulley, cam seals, front crank seal and the rear main sealeasy to do it now while the engine is out of the car Link to comment Share on other sites More sharing options...
87quest_stv Posted May 10, 2012 Author Report Share Posted May 10, 2012 Yeah, I've got the driftmotion cart full of a bunch of stuff including a rear seal for the R154 and shifter bushing too.. Link to comment Share on other sites More sharing options...
RobH Posted May 10, 2012 Report Share Posted May 10, 2012 i dont know what you are orderingif you are ordering the short shifter you only need this bushinghttp://store.driftmotion.com/static/i-marlincrawlershiftersocketr154.php stock shifter you need that one and this onehttp://store.driftmotion.com/static/i-marlincrawlerbushingr154.php i ordered them both is how i found outand the short shifter came with a metal bushing Link to comment Share on other sites More sharing options...
BOHO Posted May 10, 2012 Report Share Posted May 10, 2012 Rob, When you get time can you measure how far your water neck is from the cross member...I know this is random but it would help me. lol Link to comment Share on other sites More sharing options...
RobH Posted May 10, 2012 Report Share Posted May 10, 2012 sure man i can get that for ya now by the water neck i assume you mean the thermostat houseing ?? Link to comment Share on other sites More sharing options...
BOHO Posted May 10, 2012 Report Share Posted May 10, 2012 Yes sir. Link to comment Share on other sites More sharing options...
87quest_stv Posted May 10, 2012 Author Report Share Posted May 10, 2012 I'm excited, engine will be here tomorrow Link to comment Share on other sites More sharing options...
BOHO Posted May 10, 2012 Report Share Posted May 10, 2012 Whats up with the headlights man. I seen a 2jz before but not those... Link to comment Share on other sites More sharing options...
87quest_stv Posted May 10, 2012 Author Report Share Posted May 10, 2012 Whats up with the headlights man. I seen a 2jz before but not those... Go here for my restore thread. working on a final design that I might offer to others http://www.starquestclub.com/forum/index.php?showtopic=129075&st=0 Link to comment Share on other sites More sharing options...
RobH Posted May 10, 2012 Report Share Posted May 10, 2012 BOHOnot sure where to measure too anyways edge of thermostat housing to frame rail is about 3.5 in and straight down from the housing to the cross member is about 4 in hope this helps Link to comment Share on other sites More sharing options...
87quest_stv Posted May 11, 2012 Author Report Share Posted May 11, 2012 engine came in today http://www.getyasumminimotos.com/Conquest/2jzgte2.jpg Link to comment Share on other sites More sharing options...
BOHO Posted May 11, 2012 Report Share Posted May 11, 2012 Cool. Link to comment Share on other sites More sharing options...
RobH Posted May 11, 2012 Report Share Posted May 11, 2012 cool if you need anything let us know Link to comment Share on other sites More sharing options...
