RobH Posted March 16, 2012 Author Report Share Posted March 16, 2012 so i need to pull the trans back out i did not know that i needed to put sealer on the flywheel bolts so i am going to pull the trans tomorrow and seal the flywheel bolts all my other parts should be here monday then ill be makeing more progress Link to comment Share on other sites More sharing options...
DieHARDmitsu. Posted March 17, 2012 Report Share Posted March 17, 2012 Are you using new flywheel bolt? or reusing the old ones? Link to comment Share on other sites More sharing options...
RobH Posted March 17, 2012 Author Report Share Posted March 17, 2012 got new ones now Link to comment Share on other sites More sharing options...
87quest_stv Posted March 17, 2012 Report Share Posted March 17, 2012 quick question for ya. I see most of these 2jz's coming with auto trannys. Will the auto ecu work with the r154 tranny? Link to comment Share on other sites More sharing options...
BOHO Posted March 18, 2012 Report Share Posted March 18, 2012 The auto ecu just has an extra plug on it....Yeah its fine. Link to comment Share on other sites More sharing options...
87quest_stv Posted March 21, 2012 Report Share Posted March 21, 2012 what kind of radiator did you go with and where did you source it? Link to comment Share on other sites More sharing options...
RobH Posted March 22, 2012 Author Report Share Posted March 22, 2012 radiator here http://store.driftmotion.com/static/i-mmrad-sup-86.php fan here http://store.driftmotion.com/static/i-msh-mmfs-sup-86.php Link to comment Share on other sites More sharing options...
RobH Posted March 22, 2012 Author Report Share Posted March 22, 2012 oh and my 2jz is alive only ran it about 2 min no radiator installed yet ill get video in the morning but man it sounds bad arsss Link to comment Share on other sites More sharing options...
87quest_stv Posted March 22, 2012 Report Share Posted March 22, 2012 what about this one? http://www.jmautoracing.com/19861992-toyota-supra-megan-racing-radiator-rows-p-50867.html Link to comment Share on other sites More sharing options...
RobH Posted March 22, 2012 Author Report Share Posted March 22, 2012 yes that should work from my understanding any mk3 radiator should work for you Link to comment Share on other sites More sharing options...
BOHO Posted March 22, 2012 Report Share Posted March 22, 2012 Good work Rob....Glad to see it fired up for you.!! Link to comment Share on other sites More sharing options...
DieHARDmitsu. Posted March 24, 2012 Report Share Posted March 24, 2012 That was quick... Link to comment Share on other sites More sharing options...
RobH Posted March 24, 2012 Author Report Share Posted March 24, 2012 ill try to get some pics up soon been working alot of hours at work then staying late to work on the quest anyways everything is done with the exception of the tail shaft mount,drive shaft, exhaust and the hooking up the cooling fans Link to comment Share on other sites More sharing options...
randy Posted March 24, 2012 Report Share Posted March 24, 2012 Awaiting to see some pics. Link to comment Share on other sites More sharing options...
RobH Posted March 25, 2012 Author Report Share Posted March 25, 2012 (edited) couple more photos http://i640.photobucket.com/albums/uu127/hoskinsr/IMAG0262.jpg http://i640.photobucket.com/albums/uu127/hoskinsr/IMAG0261.jpg http://i640.photobucket.com/albums/uu127/hoskinsr/IMAG0260.jpg http://i640.photobucket.com/albums/uu127/hoskinsr/th_VIDEO0009.jpg couple of pics of another car i just picked up for 50 buckswell not even cause i found 36 dollars in the car http://i640.photobucket.com/albums/uu127/hoskinsr/IMAG0263.jpg http://i640.photobucket.com/albums/uu127/hoskinsr/IMAG0264.jpg it was a tow away and i buy the cars from the tow company if there not claimed by the owenrs Edited March 25, 2012 by RobH Link to comment Share on other sites More sharing options...
BOHO Posted March 25, 2012 Report Share Posted March 25, 2012 Great work Rob! Glad its running. Link to comment Share on other sites More sharing options...
RobH Posted March 29, 2012 Author Report Share Posted March 29, 2012 well i drove the car home from work tonight its about 20 miles each way it ran great i have a vibration in the rear of the car feels like the drive shaft when i push the clutch in it does not go away but it does come and go with different rpms Link to comment Share on other sites More sharing options...
BOHO Posted March 29, 2012 Report Share Posted March 29, 2012 Did they balance your driveshaft? I would think with Matt's mounts that your angle is good. Link to comment Share on other sites More sharing options...
RobH Posted March 29, 2012 Author Report Share Posted March 29, 2012 i think the angle is good im pretty sure its the driveshaft Link to comment Share on other sites More sharing options...
randy Posted March 29, 2012 Report Share Posted March 29, 2012 that was a fast swap RobH glad you got it done good luck. Link to comment Share on other sites More sharing options...
RobH Posted March 30, 2012 Author Report Share Posted March 30, 2012 2 days now about 100 total miles on the swap everything is great so farminus the vibration Link to comment Share on other sites More sharing options...
bha280 Posted March 30, 2012 Report Share Posted March 30, 2012 Nice job, Rob! Want to sell that eclipse? Ant thanks again for 5hat great deal. Link to comment Share on other sites More sharing options...
RobH Posted March 30, 2012 Author Report Share Posted March 30, 2012 lol i sold the eclipse Link to comment Share on other sites More sharing options...
RobH Posted March 31, 2012 Author Report Share Posted March 31, 2012 vibration is gone and man do i love the way the car drives now it was a defective rear u-joint all i have left is to clean up my wiring under the dash and put the evap box back up in and im done ill get more pics up in a day or 2 Link to comment Share on other sites More sharing options...
kyle's89quest Posted April 4, 2012 Report Share Posted April 4, 2012 Much better then the 4 cly aint it. Im impressed with how fast you got it on the road! Link to comment Share on other sites More sharing options...
