gerwulf Posted August 27, 2011 Report Share Posted August 27, 2011 i need the pop up relays and turn signal relay...like yesterday, advanced auto and rockauto dosent even carry them and i can find any online. can be off parts car as long as they work well. or if you know links to them ect. please share Quote Link to comment Share on other sites More sharing options...
alp247 Posted August 27, 2011 Report Share Posted August 27, 2011 (edited) Thats interesting you can't get the flasher relay. I bought mine at Kragen before they turned into O'Reilly. I'm not sure about the other relay though. Are you sure it's the relay for the headlights. I mean are you having a problem with them going down? If you are then it might not be the relay and you might just need to clean the headlight switches. Edited August 27, 2011 by alp247 Quote Link to comment Share on other sites More sharing options...
ucw458 Posted August 27, 2011 Report Share Posted August 27, 2011 Turn signal flashers rarely fail. Check for corrosion at all the turn signal bulbs and/or burnt out bulbs. That can cause the turn signals not to flash. Also if the turn signal doesn't light up on the dash you can check for a burnt wire trace going to the signal bulb or a bad bulb. If those causes don't fix the problem or if it's better but not quite right you will have to clean and grease the turn signal and ignition switch contacts. For the popups, Slowly push in the headlight on button. If the popups go down after pushing the switch in about 1/16" then the headlight switch either needs to be cleaned or replaced. I know this stuff is alot more work but no one wants to end up buying parts they didn't need. Quote Link to comment Share on other sites More sharing options...
Skullzaflare Posted August 27, 2011 Report Share Posted August 27, 2011 advance and autozone both carry compatible flashers, dont ask the reps they wont know Quote Link to comment Share on other sites More sharing options...
JohnnyWadd Posted August 27, 2011 Report Share Posted August 27, 2011 i have em pay shipping they are yours Quote Link to comment Share on other sites More sharing options...
gerwulf Posted August 27, 2011 Author Report Share Posted August 27, 2011 well the pop up relays i do need as far a fog relay too, as for flashers, right works..left dosent(turns on, no blink), so could be contacts or corrosion not letting it blink? Quote Link to comment Share on other sites More sharing options...
ucw458 Posted August 27, 2011 Report Share Posted August 27, 2011 Dirty contacts, corrosion and bad bulbs are all causes for the turn signals not to work correctly. I would check the taillights first. They are prone to letting water in and that rots the bulb connections. Quote Link to comment Share on other sites More sharing options...
JAinsworth Posted August 27, 2011 Report Share Posted August 27, 2011 Go to your parts store and get an EL-12 blinker relay, that should fix your blinker issue.Jimmy Quote Link to comment Share on other sites More sharing options...
JohnnyWadd Posted August 31, 2011 Report Share Posted August 31, 2011 (edited) Go to your parts store and get an EL-12 blinker relay, that should fix your blinker issue.Jimmy yup. i like my el-12. i got it from ebay cheaper. I am sending him the fog and pop up relays Edited August 31, 2011 by JohnnyWadd Quote Link to comment Share on other sites More sharing options...
gerwulf Posted September 11, 2011 Author Report Share Posted September 11, 2011 anyone got a working fog light relay? still need one Quote Link to comment Share on other sites More sharing options...
D50tsi Posted September 12, 2011 Report Share Posted September 12, 2011 I have a tsi I'm parting right now the fogs worked in the car. Where is the relay located at on the car. Here's a like to my part out with my number in ithttp://www.starquestclub.com/forum/index.php?showtopic=123947&pid=1205627&st=0entry1205627 Quote Link to comment Share on other sites More sharing options...
