QuestFan Posted December 26, 2010 Report Share Posted December 26, 2010 (edited) So I want to put in an aftermarket boost gauge in the stock location. What I need to know is what have other members done to make this work and which gauge should I use that would blend in with the rest of the gauges? I dont want it to stand out, I want it to look factory. Other info you may need:1987MPI EDIT: Also, what size gauge do I need to use? Edited December 26, 2010 by YoungQuestFan Link to comment Share on other sites More sharing options...
starquestG54B Posted December 26, 2010 Report Share Posted December 26, 2010 (edited) http://i671.photobucket.com/albums/vv73/conquestinator/durbansnewwheel.jpgjust run the vac line thru your firewall and hook it up up to the vac line closest to the firewall on your tb then pull your gauges out. remove the stock b gauge and cut the white pvc plastic behind it . make a large enough hole to get the vac line in and DO NOT vut the green curciut baored film behind it and light in. then put the new b gauge thru the black plastic surroundsand hookit all up then put it all back together. this should also be in faq's section a good cheap b gauge doesnt look bad just no white ones or it will look stupid. Edited December 26, 2010 by starquestG54B Link to comment Share on other sites More sharing options...
starquestG54B Posted December 27, 2010 Report Share Posted December 27, 2010 standard size gauge will work. i think its 2 1/4 Link to comment Share on other sites More sharing options...
QuestFan Posted December 27, 2010 Author Report Share Posted December 27, 2010 2 1/4?!!! dam it I just ordered a 2 1/16 prosport gauge... Link to comment Share on other sites More sharing options...
BC_99 Posted December 27, 2010 Report Share Posted December 27, 2010 The 2 1/16" is the right size. So, dont cancel your order. You need to "search" for the write up on how to do this easy mod and then if you have any more questions, post them up. Most of these kinds of write ups are very detailed and can save you from being misinformed like that. BC_99 Link to comment Share on other sites More sharing options...
QuestFan Posted December 27, 2010 Author Report Share Posted December 27, 2010 The 2 1/16" is the right size. So, dont cancel your order. You need to "search" for the write up on how to do this easy mod and then if you have any more questions, post them up. Most of these kinds of write ups are very detailed and can save you from being misinformed like that. BC_99 Thanks for the info. I did find the write up I needed and it helped tremendously. Link to comment Share on other sites More sharing options...
Austin88ESiR Posted December 27, 2010 Report Share Posted December 27, 2010 Thanks for the info. I did find the write up I needed and it helped tremendously.Yeah, it is not very hard. I have an old school HKS in mine that matches the original gauges. http://www.beyonddarwin.com/Starion/starionpics/webinstrumentcluster.jpg Link to comment Share on other sites More sharing options...
starquestG54B Posted December 27, 2010 Report Share Posted December 27, 2010 yeah hes right i made a mistake. Link to comment Share on other sites More sharing options...
QuestFan Posted December 31, 2010 Author Report Share Posted December 31, 2010 Man I that prosport gauge I ordered was too deep. It's the electric one not the mechanical. So I just stuck a Sunpro narow band A/F Ratio gauge in there for now untill I get a wideband. I put the boost gauge below my radio. Link to comment Share on other sites More sharing options...
D_Venable Posted January 3, 2011 Report Share Posted January 3, 2011 I run the mookeeh gauge overlays, and put a GlowShift gauge in the flatty. It was also a little deep, but the face of the gauge was back far enough I just cut the barrel back, and the opening in the black plastic was just right. The gauge sits all the way back onto the white plastic as well. While cutting the can though, the needle on the gauge broke, so I modded the stem of the glowshift needle, to accept the stock boost gauge needle (repainted the backs) http://www.26liter.us/gallery/albums/userpics/10030/P8150592.jpghttp://www.26liter.us/gallery/albums/userpics/10030/P8150591.jpghttp://www.26liter.us/gallery/albums/userpics/10030/P8150589.jpg Link to comment Share on other sites More sharing options...
techboy Posted January 3, 2011 Report Share Posted January 3, 2011 Just a side note for anyone ... I had a set of Prosport guages for my Eclipse at one point. I was not impressed. There's a reason they are cheap. I ended up going back to Autometers. Link to comment Share on other sites More sharing options...
Cole Posted April 24, 2011 Report Share Posted April 24, 2011 i just found an Auto Meter gauge that I'm goingt o buy to put into the stock place. In my opinion, this one would best blend w/ everything. The needle isn't orange but chromish. The only thing that would stand out a bit is the carbon fiber.http://d5otzd52uv6zz.cloudfront.net/2b008681-ea28-4691-907e-78fff083269d-800.jpg Link to comment Share on other sites More sharing options...
BrazilBoy Posted April 24, 2011 Report Share Posted April 24, 2011 (edited) http://www.racetep.com/starbg.html What they forgot to mention is to gap the gauge cluster lens a little so the gauge itself doesn't contact cluster lens causing spider cracks.. Edited April 24, 2011 by BrazilBoy Link to comment Share on other sites More sharing options...
QuestFan Posted May 2, 2011 Author Report Share Posted May 2, 2011 http://www.racetep.com/starbg.html What they forgot to mention is to gap the gauge cluster lens a little so the gauge itself doesn't contact cluster lens causing spider cracks.. Yup, had that same problem, I just didnt crank down on the screws. But it does not matter now since I have a prosport evo series wideband in there. Link to comment Share on other sites More sharing options...
81zfan Posted May 6, 2011 Report Share Posted May 6, 2011 In the above "how to" it shows that you cut the circuit film when installing the gauge, but won't cutting this cause other things in the cluster not function correctly. I have been searching for a write up as well, and the only one in the FAQ'S tells how to hook the vac. up to it. Link to comment Share on other sites More sharing options...
QuestFan Posted June 13, 2011 Author Report Share Posted June 13, 2011 In the above "how to" it shows that you cut the circuit film when installing the gauge, but won't cutting this cause other things in the cluster not function correctly. I have been searching for a write up as well, and the only one in the FAQ'S tells how to hook the vac. up to it. Either get an electric boost gauge or just be careful not to cut into any of the circuitry when making a hole in the film. Link to comment Share on other sites More sharing options...
The Rabbit1 Posted June 13, 2011 Report Share Posted June 13, 2011 In the above "how to" it shows that you cut the circuit film when installing the gauge, but won't cutting this cause other things in the cluster not function correctly. I have been searching for a write up as well, and the only one in the FAQ'S tells how to hook the vac. up to it.as long as you don't cut the copper strips your ok. and if you do.. I jumpered mine and they work fine. Link to comment Share on other sites More sharing options...
Lance_S Posted June 16, 2011 Report Share Posted June 16, 2011 Can anyone give me a depth for how much room is back there. Getting ready to change the boost gauge out and want to know what to order. Link to comment Share on other sites More sharing options...
AustinTSI Posted December 14, 2011 Report Share Posted December 14, 2011 Does anyone know for sure if a 60mm gauge will work. The normal size people use is 52mm but I have a specific one that is 60mm that I want to use and don't know if it will fit. Link to comment Share on other sites More sharing options...
