coil arching
I have F.I.P set up(both fuel and ignition)with Mallory ignition and a Holley coil and it is arching. I had a Bosch coil on there before and had to remove it because it arched worst. Has any one experienced this?
Sounds like your rotor is not phased propperly with the engine. The ECu will set the timing, but the rotor still needs to be in the correct place when teh spark signal is sent. If it's not, the spark has nowhere to go but to the neg terminal on the coil lead. The bocsh was probably a highe rvoltage spark, so it arced more severly as it had more energy to jump the the neg termnal.
You might also want to check the plugs and wires for defects/flaws (resistance check on the wires).
Interesting, when i had the Jacobs ignition it arched as well. the Bosch did it and now the Holley. what do you mean phased? it did that before i was M.P.I so now its even more apparent. So it seems this has nothing to do with the fact I cant sett my dizzy properly right?
Chad, how easy is it to mod the water neck on my magna?(what should I do?)
the dizzy was modded my FIP BTW.
What ever sensor it uses to signal the ignition to discharge must still be timed to the distributor if one is used. You can't have a distributor rotor in between to poles and the spark discharged that is what Chad is saying. You have to set up the distributor offset first thing. This offset is also used in calculating total timing. If you have an ignition map and it is set up for 10btdc at idle and the offset you set up the dist. to is 2 and you put the timing light on the and watch the crank pulley it will not flash at 10, it will be 2 degrees off. Sounds like you are way off. It may be firing on the wrong cylinder and that would mean your injectors are not firing like you think they are. It must start hard if at all and run like crap if that is what is going on.
The motor shakes like crazy when it runs along with the arching. its the FIP modded dizzy so the caravan module is timed to the dizzy?, man I'm confused. I will post some pic this weekend
the only reason the coil will arc is if that spark has no where to go, which means the rotor man not be propperly phased with the motor, so the spark misses the pole in the cap all together.
It may also be a bad cap or rotor, but I doubt that.
It may be defective plugs, but I doubt that.
It may be bad plug leads (wires), that is my guess personaly. Using an ohm meter, make sure they all have about the same resistance per-foot, you will expect to see 1000 ohms per foot. May be much more or much less (depending on brand) but they should all be about the same per foot.
It may also be a bad connector on one of those leads (another good possibility).
If the ECU is timed propperly to the crank, you'll have good timing even with this phasing issue, which is why the car will still run OK.
If it's been a while or a lot of miles, you may want to replace the cap/rotor/wires/plugs just to be sure.
I have Magnacore wires fairly new, plugs are fairly new(0 miles but alot of time has elapsed since we fired the car up) we'll run through everything like you said. The ecu is timed at 10TDC.
From what I have seen with aftermarket spark controllers like MSD, Mallory and such you have to set the motor to 20 degrees BTDC and line the rotor up with the number one terminal by stabbing the dist in the correct place. I had this similiar problem and realized I had to have the body of the distributor cranked all the way down to get the rotor to phase properly. Try this and see if it improves. Sounds like you have it set correctly in the ECU itself at 10 degrees. Now you have to line it all up mechanically. ;) Edited by ElkidminoLTU
if i turn the dizzy to the right it hits the water neck on the magna. all the way down(to the front of the motor and it wont start.)
Oh, we had to do that with the Magna distributor too, we turned the drive gear half turn and that solved the problem.
End up stuck way up there right? You never said you had a Magna distributor.
http://www.b2600turbo.com/images/IM001053.JPG
Something had to be changed: the stud in the head, the slot in the dist. body, the t-stat housing on the manifold or move the dist. drive gear. On this unit, its aftermarket by the way, there were 4 holes instead of the usual 2 on a C/S dist. There are 12 teeth so of the 720 degrees of crank angle (2 turns crank=1 turn cam) one tooth is 70 degrees. We had an adj. range of about 20 crank degrees. This put the initial timing too far off. Easiest solution was to drive the pin out and rotate the gear 180 degrees (half turn) and put the pin back in. You can see this is before the gear was repositioned. On one side the holes are in the bottom of a tooth and the opposite side it is at the top. (there were two sets holes in this gear I don't think the factory units are like this)
http://www.b2600turbo.com/images/IM001583.JPG
http://www.b2600turbo.com/images/IM001581.JPG
We set the dist. up so the trigger offset and base timing combined so that when we looked at the ignition map all the numbers in the table were the actual total timing that way we didn't have to do any math to come up with total timing. You can set it up how you wish.
Is this the position that it's in now? it won't rotate counter-clokwise? Looks too far clockwise now, by a whole lot.
that horizontal line in the distributor hold down flange should be about level with the top of the head surface, not above it 3/4".
http://img26.imageshack.us/img26/2660/dsc01857b.th.jpg
Where is the distributor hold down stud?
This software uses megatune right? did you go through the steps to set up the trigger offset? You have to have the offset set up close to zero of the motor won't fire right so you can start it up. You have cranking and after cranking numbers for rpms to set too. You will still have to change the drive gear unless it already was before you got it.
One other option is to re-position the spark plug wires but you have to remember that and tell anyone else later that gets the car so that they will be aware that they are not in the same order on the cap that most would assume to be correct. You would put the #1 wire where the #4 would normally be then go around in the proper firing order clockwise on the cap.
I got a great deal on a 1967 Eldorado from a guy long time ago he said he knew the car ran but couldn't get it to start for nothing. I got it for 500.00, this was like 1997, and someone had put the plug wires on the cap and used the wrong position to start and that's all that was wrong was he was looking at the cap upside down I suppose with it but I did all that after I got it home. He checked it over and over and just didn't catch the mistake.
it will rotate but wont start in the counter clockwise position. after it starts if i rotate counter clockwise it will run rough then stall.
its a fip modded dizzy. so, line it up horizontally all the way counterclockwise like its supposed to be then reverse the firing order the wires starting with #4? correct
Hmm, I'm still thinking that is not correct. Your missing the stud on the front of the head for the distributor lockdown so wherever you lined things up at TDC, the distributor is waaaaaay off. The only thing a FIP modded dist contains is locked down wieghts and the advance is locked down too. I see you are using a mallory? ignition so your dist should be installed with the motor at 20* BTDC. Meaning set the motor to 20* BTDC and stab the dist so the rotor lines up to the number 1 terminal. First thing first, get a stud in that front bolt hole of the head for dist lockdown! An exhaust stud will do the trick!
I will try that. so never mind that the dizzy can't be clocked clockwise right? on the ignition pro do i set it at 20btdc as well?
Ya know, i find this thread very interesting because I have a similar issue. I have had two coils that arch between the center coil wire to the negative post. I also have a Mallory Hyfire , FIP fuel and Ignition. The two coils were MSD blaster 2's and now I am running one i bought off Summits site called a flame thrower. So far it seem to work with no arching. But, like it has been said on this thread, that you must phase the distrib and the ignition map, I can not get my ignition to match at anything lower than 15 degrees. It runs fine at 15 mind you, but there is no more adjustment. I have the car all together, MPI, screeming banshee cam with mechanicals, and 50 trim garrett turbo. On the dyno, it would only make 245 hp. What the @#$. The tuner told me that the hp was dropping off after 5000 rpm's and that my timing was not retarding enough, that i was running closer to 24 degrees under boost and rpms. He went on to tell me that the distrib is out of phase. I really have no clue at his point, I pulled the distrib all apart to see if it have moved after it was modded, or if something else was wrong. It looked perfect and matched up with the FIP website. I do know that the distrib is stabbed correctly, because I have a cap that i drilled hole in to see where the rotor is. As of now, I am lost as to how to fix it.
we'll get past this together. I will be able to work on it Wednesday and post new results. Thanks guys keep it coming.
Cool, good luck with it. I may try rotating the engine around to 20 degrees then stab the distrib trick. Who knows, maybe theres something to it I am overlooking.
SO you don't use megatune with this? This is a basic part of the software. Same issue we had until the cracking offset was set. You can't have it be like 50 degrees of the motor won't start it has to be firing in the range a stock ignition setup would fire in and then when it starts you have to get it to the same stock range so it will run and its that offset you seem to have over looked.
Here's what you should do then, put a timing light on the engine and have someone crank the motor over and you set the dist. up so the light flashes at TDC. That should allow the motor to start. After it starts it should use the ignition map and move to 10btdc same as a stock setup. You don't want the motor to start so pull the plug wires off or something, disable the fuel supply.
Indiana, thanks for the help. Let me try to understand. You are saying set the crank off set without the car running, and set it as 10BTDC? I did use the megatune software to match the static timing to what I was seeing on the timing light. The problem I am having is that I can not rotate the distrib any further towards the firewall. Unlike lionbull, I have a stub in the head to lock mine and the distrib doesnt hit the manifold. If i pry a screwdriver in the distrib slot and pry it against the head to rotate as much as i can, then lock it down, the best I can get is 15btdc. At 1000 rpms in Metatune, I am trying to match that and I can. I can even pull out more timing at idle with the software. But the problem has to be in the distributor or the timing chain.
