Conquestdetaco Posted May 29, 2003 Report Share Posted May 29, 2003 Can someone tell me which alternators we can grab off another model car that will just bolt in?? I think I read somewhere that a GM Alternator from a 97 or so Camaro will work. They are rated at 140 amps I believe. My brother works at a shop where all they do is rebuild/replace alternators. I was gonna have him rebuild my stock unit since I am getting poor output from it, but I learned it only churns out about 65 amps. That is weak. So if anyone knows of any other alternators which will bolt on and work that would be awesome. I would get the unit that Tim C sells but I cant afford 200 bucks right now. I got rid of my a/c and alternator bracket and got the 4 dollar bracket from Mitsubishi if that makes a difference. If I find that they have a particular alternator with higher amps that we can use I know I can get a great group purchase price. Thanks guys Link to comment Share on other sites More sharing options...
Yellow_quest Posted June 1, 2003 Report Share Posted June 1, 2003 have your bro rebuild it and beef it up...theres a shop here in Kc that said they can get 85-90 out of it easy...tim_C has the 100 and 140 amp's for sale also. Yellow_quest Link to comment Share on other sites More sharing options...
JessN16 Posted June 17, 2003 Report Share Posted June 17, 2003 Highly recommend Tim C.'s alternator. Good price for good parts and they bolt right in. Jess Link to comment Share on other sites More sharing options...
Conquestdetaco Posted June 17, 2003 Author Report Share Posted June 17, 2003 I may be mistaken but I think Tim uses a CS-130 AC Delco...or similar. My brother is getting me a new one with 110 amps ...all I need to do is make a braket and it should bolt right in. I will let you guys know how it comes out. Thanks Link to comment Share on other sites More sharing options...
rickyturboic Posted September 16, 2003 Report Share Posted September 16, 2003 ??? Hey guys I tried to find here in Puerto Rico the AC delcoalt. but in the auto parts said to me tha those alts have a 9 digit serial number, I would like to Know if any of you have the serial# , because i have a really big problem I have my amps and my lights on and my altermnators` charge is in about 12.5v and that`s too poor, any other advice I`ll apreciate! Link to comment Share on other sites More sharing options...
dizzydug Posted November 28, 2003 Report Share Posted November 28, 2003 Go an get a stiffening capacitor(1 fared) and an Interstate "Megatron"battery and that will solve a lot of problems.If you still have trouble than your electrical system has a problem elsewhere.Bad grounds,corroded wiring ect. Back when I my 75 camaro I had 2 punch 150's and a power 300 and just had the stock chevy alternator.Around 60-65 amps like our cars I think.That interstate megatron has 120 minutes of reserve power and a lot of juice to boot.Never had a problem with anything electrical and that was in an old car.Those 3 amps drew 100 amps. Later I added a second battery as I then ran the power 300 and a power 650.Also had a dual battery isolator so the alternator would only charge the battery that needed it.Worked well in that car. The newest of our cars being 14 years old;almost 15 I think maybe the stock alternator will need to be replaced or rebuilt.Don't expect a 15 + year old electrical system to run your car plus 1000 watts of stereo equipment. If you can get a high amp alternator to bolt up and hook up to our car then all the better.I have seen a Pheonix gold alternator in a starion once.They make a universal bolt on of some kind.Brackets has to be made to work ofcourse.There is no cheap route. Link to comment Share on other sites More sharing options...
rickyturboic Posted March 17, 2004 Report Share Posted March 17, 2004 [glow=red,2,300]TEXT[/glow] Guys i found a good alt for the starquest!!! I used the factory alt of an 1995 eclipse awd turbo the only thing you have to do is to jump two cables from the original harness to the corresponding "L" and "S" cables of the alternator it fits quite simply, and put some shims in the lower bolt between thw alt and the engine block, my car is runing whith two amps, radio, x-over, headlamps, and its pulling an amzing 13.3volts at idle. Just to let you know Link to comment Share on other sites More sharing options...
JustPaus_88TSi Posted March 17, 2004 Report Share Posted March 17, 2004 Just to clarify, there's no "drop in" alt that will fit properly...Alternators have to be SPOT ON...If it's not perfect, the alt will die prematurely... Tim C. is the only way to get a "drop in" 110 or 140 amp alt.... Everything else requires custom pully's or brackets etc.... Link to comment Share on other sites More sharing options...
xXCONQUESTSIXx Posted March 17, 2004 Report Share Posted March 17, 2004 my dad used an alternator off of an 94 eclipse for his 85 starion. every time you hit the gas the lights got alil brighter lol. Jeremy Link to comment Share on other sites More sharing options...
jolyrgr Posted March 17, 2004 Report Share Posted March 17, 2004 I would highly recommend the Tim C. alt. I've been running for over a year and 20k+ mi without a problem. The delco alt he sells was origionally for a boat app if I am thinking correctly, but the money is spent on the bracketry and the r&d time he and his shop put in. The internals are far superior to the mitsu stock esp the bearings..........HUGE. I showed this to my local alt rebuilder and he said this unit was cap of putting out 150+ amps with the proper modifications. Yeah, $200 is a lot of cash, BUT you get what you pay for and I have not regretted it in the least. Link to comment Share on other sites More sharing options...
Starcon88 Posted March 22, 2004 Report Share Posted March 22, 2004 I really don't know of any GM alternators that bolts in the factory bracket. My 110amp 3000gt alternator bolts right in and plugs right in the factory harness all you need is a custom pulley, my alternator has been very good to me its been over 15k miles and has been on 2 conquests and still operating excellent, actually right now i'm in the process of selling a few kits but either GM or Mitsubishi, a 110amp alternator is an excellent upgrade very noticeable. Â Â Kurt Link to comment Share on other sites More sharing options...
1st_gen_eclipse_89 Posted May 12, 2006 Report Share Posted May 12, 2006 i had an alt. from my old 97 5.7 camaro that i bought and never used and i fit it to my starion block with the help of a custom bracket, some washers,and a new pulley, and this thing is lighting up my dash like a christmas tree!!! :shock: my volts never drop below the second mark from the top. even at idle with everything turned on!! its rated at 200 amps from the factory so this is the one to get. it pisses me off because i just eliminated my electric fans for a clutch fan because of the draw on my stock alt. :x , and now im sure they wouldnt be a problem with this 200 amp alt. oh well, you live and you learn. Link to comment Share on other sites More sharing options...
