Convette Posted May 5, 2013 Report Share Posted May 5, 2013 (edited) Ok, getting this done now, and I need to know whos interested. I have thoroughly tested them on the street and under extreme track use. The bracket will allow you to bolt up 98-04 mustang cobra 13" PBR calipers to the front of a stock quest with a little bit of work. They are hand made out of 3/4" T6061 T6 aluminium, like just about every big brake kit in the world. You can buy what you need on ebay for $300-$400 for the complete set up, or you can piece it together yourself. Also, parts are SUPER cheap, and you can get pads and rotors at ANY auto parts store. So far, this is the cheapest big brake upgrade I've seen for our cars. PLEASE NOTE: The brakes are NOT a direct bolt up. The hub bore on the quest it too large for the mustang rotors. You have two options, have the hub turned, or have the rotors turned. I recommend having the hubs turned because you will change rotors more than you change hubs. Also the caliper itself will need to have one of the ears grinded down to make work, it serves no purpose, but needs to be clearenced so the caliper can move. (more on this later, its a 2 min side grinder job) ALSO NOTE: They will not work with stock wheels! 17's and up only. I made them as close as possible, but the calipers are large. I can provide dimensions for them so you can check. *As you all know, these are in no way DOT approved and by purchasing, you assume all liability by installing these on your car. *Off road use only. I will provide online direction and as much support as possible to ensure that they are installed correctly for your safety. We are looking at $130 shipped, all hardware included. *Update 5/9/13 Fitted up last night, all good to go. Obviously the stock dust shield will have to be trimmed or removed to allow installation. Please send payments via paypal to JLIII9788@yahoo.com whos in so far.. 1 Kidjc paid $130 5/15/13 shipped2 Crazy Quest3 Tae paid $130 5/15/13 shipped4 Nomad Paid $130 5/17/13 shipped5 theboyo19 Paid $130 5/21/13 shipped6 creakyjoints Paid $130 5/16/13 shipped7 dmyers151 Paid $134 5/18/13 shipped8 Sellerfeller Paid # 130 6/2/139 DieHARDmitsu Paid $130 5/17/13 shipped 10 KIDMEN For comparison reasons,http://i177.photobucket.com/albums/w239/johnboy9788/20130520_095019_zps3052be02.jpghttp://i177.photobucket.com/albums/w239/johnboy9788/IMAG1619.jpg http://i177.photobucket.com/albums/w239/johnboy9788/20130509_093040_zps8c4b7940.jpg http://i177.photobucket.com/albums/w239/johnboy9788/20121018_171032.jpghttp://i177.photobucket.com/albums/w239/johnboy9788/20130106_162325.jpg Edited June 3, 2013 by Convette Quote Link to comment Share on other sites More sharing options...
kidjc Posted May 5, 2013 Report Share Posted May 5, 2013 Hey John... I think this to be a very viable alternative, since Stang parts are so readily available, & really quite reasonably priced. Also, they're not gonna go away. When you say all hardware included: ? I believe I would be interested in getting in on this, thanx, & you can put me down, as I have been going back & forth on where I really want to go w/ a Big Break System. Is this gonna be front only for now? Or... is there a possibility of rear coming into the picture? If for nothing else, to match up? Thanx dude! Quote Link to comment Share on other sites More sharing options...
Convette Posted May 5, 2013 Author Report Share Posted May 5, 2013 (edited) Yes I agree, its by no means the best system but, it is better and larger than stock, also provides use of any upgraded brake system for a mustang 98-2004. Anything that uses the stock mustang mounting points will work, plus MUCH better options for pads. You could do this mod for around $500 total. By hardware I mean 8 mounting bolts w/ washers and 2 brackets. I am going to be developing something for the rears soon, most likely be for a separate caliper for the hand brake. Edited May 5, 2013 by Convette Quote Link to comment Share on other sites More sharing options...
creakyjoints Posted May 5, 2013 Report Share Posted May 5, 2013 (edited) http://www.americanm...conversion.html These will bolt right up? http://sn95forums.com/archive/index.php/t-45317.html Edited May 5, 2013 by creakyjoints Quote Link to comment Share on other sites More sharing options...
Crazy Quest Posted May 5, 2013 Report Share Posted May 5, 2013 I'm in there like swim wear That means yes Quote Link to comment Share on other sites More sharing options...
taeisallin Posted May 6, 2013 Report Share Posted May 6, 2013 Just what I've been waiting for. Count me in. Tae Quote Link to comment Share on other sites More sharing options...
Convette Posted May 6, 2013 Author Report Share Posted May 6, 2013 (edited) http://www.americanm...conversion.html These will bolt right up? http://sn95forums.co...hp/t-45317.html yes, with a little work. 1998-2004 13" cobra PBR's ebay linkhttp://www.ebay.com/...1bbcf5e&vxp=mtr list started. Updated design almost done. http://i177.photobucket.com/albums/w239/johnboy9788/20130505_194130_zps881ce4fc.jpg Edited May 6, 2013 by Convette Quote Link to comment Share on other sites More sharing options...
nomad Posted May 6, 2013 Report Share Posted May 6, 2013 I'm in for this too. Do you think that the stock Booster and master cylinder are adequate for the larger calipers? I know you are using mustang parts there also, and say it was a big hassle. Quote Link to comment Share on other sites More sharing options...
Convette Posted May 6, 2013 Author Report Share Posted May 6, 2013 Since they are only 2 piston not 4, the stock master should be fine. I'll add you to the list. Quote Link to comment Share on other sites More sharing options...
theboyo19 Posted May 6, 2013 Report Share Posted May 6, 2013 oh... oh my.... Im in... Quote Link to comment Share on other sites More sharing options...
NikoFab Posted May 6, 2013 Report Share Posted May 6, 2013 (edited) This is awesome...good on you sir! I was getting nowhere with Wilwood without at least 20 orders. Edited May 6, 2013 by NikoFab Quote Link to comment Share on other sites More sharing options...
creakyjoints Posted May 6, 2013 Report Share Posted May 6, 2013 Sounds good. Add me for a set. Quote Link to comment Share on other sites More sharing options...
dmyers151 Posted May 6, 2013 Report Share Posted May 6, 2013 Put me in. I need an excuse for 17's. Quote Link to comment Share on other sites More sharing options...
sellerfeller Posted May 7, 2013 Report Share Posted May 7, 2013 very cool... i would like to be in on this as well. Quote Link to comment Share on other sites More sharing options...
Scotty Dont Posted May 7, 2013 Report Share Posted May 7, 2013 I might get in trouble for this but, throw me in for a set. Quote Link to comment Share on other sites More sharing options...
Convette Posted May 7, 2013 Author Report Share Posted May 7, 2013 Haha. Got the first set done. Just going to double check fitment on a stock car before I take any payments. http://i177.photobucket.com/albums/w239/johnboy9788/20130507_105815_zps123c5bda.jpg Quote Link to comment Share on other sites More sharing options...
dmyers151 Posted May 7, 2013 Report Share Posted May 7, 2013 Get some logo on there son, promote the product! Quote Link to comment Share on other sites More sharing options...
Convette Posted May 7, 2013 Author Report Share Posted May 7, 2013 Dont worry. logos come last. Quote Link to comment Share on other sites More sharing options...
dmyers151 Posted May 7, 2013 Report Share Posted May 7, 2013 Legit. Quote Link to comment Share on other sites More sharing options...
DieHARDmitsu. Posted May 7, 2013 Report Share Posted May 7, 2013 Put me down for a set bro! I'll grab another later. Quote Link to comment Share on other sites More sharing options...
Fuze Posted May 8, 2013 Report Share Posted May 8, 2013 I am going to be developing something for the rears soon, most likely be for a separate caliper for the hand brake. Dag, I wanna keep my 16's but just bought a front spindle/brembo brake setup from a FC RX-7, guess I'm going that way.. The rear double caliper setup, I am in! Quote Link to comment Share on other sites More sharing options...
Convette Posted May 8, 2013 Author Report Share Posted May 8, 2013 right on man. Post up some pics when you get them on. Quote Link to comment Share on other sites More sharing options...
KIDMEN Posted May 8, 2013 Report Share Posted May 8, 2013 Count me in on this too this is awesome Quote Link to comment Share on other sites More sharing options...
Convette Posted May 9, 2013 Author Report Share Posted May 9, 2013 Post updated Quote Link to comment Share on other sites More sharing options...
Convette Posted May 15, 2013 Author Report Share Posted May 15, 2013 Now taking payments! Check the first post for paypal info. Quote Link to comment Share on other sites More sharing options...
