abs delete line adaptor
JohnnyWadd
10mm 1.0 pitch inverted flare. 30 inches. I bent both of mine by hand with no issues. No adapters are needed on the lines. Standard flare will not work. You will barely be able to thread the nut in to the master cylinder or proportioning valve. It will also probably not seal. If you want to clarify standard vs inverted the correct one is the one with the nut that has threads all the way down. The wrong one had threads then it had a smaller diameter unthreaded shaft headed towards the flare.
Sources: Did this last week on another quest and I bought the standard flare by mistake first.
http://www.andyz28.com/1lecd/brake%20lines/tube%20nuts.jpg
You want the one on the left.
http://www.andyz28.com/1lecd/brake%20lines/index.htm
The ’82-’83, and very early 1984 cars used the same fitting that had been the standard in the automotive industry for decades, the “inverted flare”.
Edited by ColdScrip
These aren't camaro's man... if you looked at the stock flare when you took it off, you'd be able to see it wasn't like that.
http://img98.imageshack.us/img98/5636/flare.jpg
-Robert
-Robert
Really? I looked it up as a picture for reference. Obviously these aren't camaros. I quoted that section to show that it is called an "inverted flare" and that the left nut is what you should look for. Maybe its the frustration of trying to fix electrical gremlins on a quest atm but I am amazed that you thought I was implying to get that camaro line.
Edit: This is coldscrip, on Dad's comp at the shop.
Edited by Dad
Perhaps i'm confusing bubble flare for standard flare.
Edit: I believe its called standard inverted flare which is what we have.
The kind that we don't have is the bubble flare. Regardless going by the above picture (left nut) will prevent you from getting the wrong one.
Edited by ColdScrip
If you want to make your own you can do it easily. Once i found all the right parts i realized that. Anyway you just need a -3AN line like this that is 19" in hose length and has the 90 degree end. (a 120 degree end would work on the one side for the master cyliner)
Like this..
http://img638.imageshack.us/img638/1646/20110112204056.th.jpg
And a pair of adaptors that are 10mmx1.0 to -3AN.
the adapor is a fragola part number 650310
the factory crimped hoses are available at many places including ebay and www.verociousmotorsports.com and http://fragolaperformancesystems.com/30steelbrakeadapters/steelbrakeadapters.html
I looked at the pic in the link and the inside of the flare wasn't correct, that's what I was saying. I was on the phone at the time and didn't get a chance to fully type it out.
http://www.andyz28.com/1lecd/brake%20lines/flares.jpg
The inside of the flare doesn't look correct.
http://static.speedwaymotors.com/images/charts/BrakeSystem-TechTip.gif
It's called a double flare, or double inverted flare.
http://www.waterbugdesign.com/pics/keypad/DoubleFlareDiag.jpg
How to make one.
-Robert
How to make one.
-Robert
Gotcha I didn't delve further as that pic showed the nut and thats all I was trying to show. Perhaps it would have been better if I didn't cite my source lol.
Edit: Coldscrip again lol
Edited by Dad
It's probably cuz you linked a camaro source!!
-Robert
