jmmy Posted September 7, 2010 Report Share Posted September 7, 2010 So I want to lower my car and update the 23-year-old suspension. Are there any more under $500 options than Suspension Technique springs or Ground Control coilovers? Which one would be best? And I'll need some new shocks as well, I assume Tokico is the best I could get? Link to comment Share on other sites More sharing options...
89PalermoSHP Posted September 7, 2010 Report Share Posted September 7, 2010 eibach would be my first choice in a stock replacement then st since eibachs may be more difficult to find. they will lower it about an inch or so. just on the edge of decent camber specs. as for struts, good luck finding tokicos and get the wallet out if you do find them. there are a few options but direct replacement is getting harder to come by for all four corners. Link to comment Share on other sites More sharing options...
Fanta Posted September 7, 2010 Report Share Posted September 7, 2010 Cosmo Racing coil overs Link to comment Share on other sites More sharing options...
FLATBROKE313 Posted September 7, 2010 Report Share Posted September 7, 2010 + 1 on cosmo coil overs luv them and installed the right way you will to! Link to comment Share on other sites More sharing options...
jmmy Posted September 7, 2010 Author Report Share Posted September 7, 2010 "installed the right way" hmm does that mean that it's common that they're usually not installed correctly? what are some precautions one should take when installing them Link to comment Share on other sites More sharing options...
FLATBROKE313 Posted September 7, 2010 Report Share Posted September 7, 2010 From what i hear people dont use the rubber o rings provided and here alot of noise.I use the rubber o rings and then used black electrical tape over them real tiet fit but you wont get the CLUNKING noise and just all around a better install and if you need any more advice i would be glad to help. Link to comment Share on other sites More sharing options...
dem0ntsi Posted September 7, 2010 Report Share Posted September 7, 2010 When I get my D2s installed Ill be putting up my Cosmo coil over/MK1 shock set up for sale if you are interested. Link to comment Share on other sites More sharing options...
Komeuppance Posted September 7, 2010 Report Share Posted September 7, 2010 Well... how low are you trying to go?? This will determine your choices. -Robert Link to comment Share on other sites More sharing options...
jmmy Posted September 8, 2010 Author Report Share Posted September 8, 2010 like 2 maybe 3 inches lower than stock. i'm considering cosmo coilovers and mookeeh struts. would that be any good? Link to comment Share on other sites More sharing options...
Komeuppance Posted September 8, 2010 Report Share Posted September 8, 2010 The real advantage of the cosmo coilovers is adjusting your height to where you want it. MK1 struts should work fine, he stated they were designed with lowered cars in mind. You should save up for some camber plates as well to dial in your suspension. If the MK1 shocks wear out too fast, you can go with KYB MR2 GR2 shocks for about $44 each, run a shock spacer inside the housings if you don't want to cut them down. You'll have to change your top hats or resize the MR2 struts because they are larger threaded shaft. -Robert Link to comment Share on other sites More sharing options...
Caliber308 Posted September 8, 2010 Report Share Posted September 8, 2010 (edited) Two or three inches below stock? If so, About your only option is Adjustable coil-overs. Mooketh has, or had them,Cosmo still sells them on E-Bay. But, with lowering your car that much you will also need Adjustable Camber Plates. Don't want to install them? Plan on replacing your tires on a more than regular basis. CALIBER 308 Edited September 9, 2010 by Caliber308 Link to comment Share on other sites More sharing options...
yokomo Posted September 9, 2010 Report Share Posted September 9, 2010 Well... how low are you trying to go?? This will determine your choices. -Robert Just bag your car already get some titanium scrapper plates! then make vids of you scrapping at 100mph, put em on Youtube and you will be famous! <- thats a fukin ninja! Link to comment Share on other sites More sharing options...
Komeuppance Posted September 9, 2010 Report Share Posted September 9, 2010 Just bag your car already get some titanium scrapper plates! then make vids of you scrapping at 100mph, put em on Youtube and you will be famous! LOL... nah, I don't need bags. If I can't get to the place, it's not worth getting to... or I'll just take one of my other cars... LOL. -Robert Link to comment Share on other sites More sharing options...
