Starting the KongQuest. LS Powered Convette Inspired Beast
ls swap
958 replies to this topic
#41 autotr8er2
autotr8er2
    Out of my Cotton Pickin' Mind
  • 993 posts
Posted 27 December 2013 - 05:17 PM
I bought two extra tires and wheels for each caster. the caster is a ten inch tire.  It uses a 5/8 shoulder bolt.  Drilled out one side of the caster with a 5/8 drill bit.  Got some 5/8 steel rod, measured the length I needed for all three wheels plus about 3/8 on each end 14 inches, I think.  Drilled holes on each end to put cotter pins into and assembled them.  I found the video on YouTube mikes DIY triple threat casters, was the title, I think.
#42 autotr8er2
autotr8er2
  • 993 posts
Mikes DIY projects. How to make triple threat casters.
Edited by autotr8er2, 27 December 2013 - 05:24 PM.
#43 autotr8er2
autotr8er2
  • 993 posts
Posted 01 January 2014 - 09:16 PM
I don't know what I came down with but still too sick to do anything. Just going over ideas for the front and rear suspensions and drivetrain.  Happy New Year!
#44 Convette
Convette
    I used to driftjunk
  • 4,990 posts
  • Interests:Going faster
Posted 02 January 2014 - 11:47 AM
Nice man, coming along.  Spring is right around the corner get it done!
#45 Xtreme Industries
Xtreme Industries
  • 1,538 posts
  • Interests:cars
Posted 02 January 2014 - 02:48 PM
that spoiler looks great! are you goint to have to tub the rear to fit those wheel/tire size?
1991 BMW 318i - RIP
#46 autotr8er2
autotr8er2
  • 993 posts
Posted 02 January 2014 - 10:55 PM
Yep, I'll tub the chassis to fit those meats.  I may just cut the fenders and step them out to make them like the SCCA trans am racers of the 80's.  I'm going to have a friend of mine make up some sketches to see if they will look right.   The car is so sexy already, I'd hate to screw it up.
#47 autotr8er2
autotr8er2
  • 993 posts
Posted 02 January 2014 - 10:59 PM
What do you think of the wheels?  Don't have them yet.  I'm leaning very heavy towards these, though.
Edited by autotr8er2, 02 January 2014 - 11:00 PM.
#48 D3UC3S
D3UC3S
  • 326 posts
  • Interests:Cooler than a polar bears toenails
Posted 02 January 2014 - 11:02 PM
Not a fan of the 370 wheels... Only OEM wheels I like are the Terminator Cobra wheels on a SQ
Edit: those actually look like the new vette wheels
Edited by D3UC3S, 02 January 2014 - 11:03 PM.
Banana-rama 88 'quest
#49 autotr8er2
autotr8er2
  • 993 posts
Posted 02 January 2014 - 11:05 PM
After a near tragic event, I purchased a new 2000lb engine stand from Harbor Freight.  I was using a borrowed stand and the engine was so heavy, it bent stuff.  The A/C compressor broke during the event and I had to put in two helicoils in the lower mounting points for the transmission.  I haven't sweated so much in my life.  Minor setback.
#50 autotr8er2
autotr8er2
  • 993 posts
Posted 02 January 2014 - 11:07 PM
Yep, Corvette wheels.
#51 autotr8er2
autotr8er2
  • 993 posts
Posted 02 January 2014 - 11:13 PM
I'm using c5 spindles on all four corners.  These are the right offset for the suspension.
#52 autotr8er2
autotr8er2
  • 993 posts
Posted 02 January 2014 - 11:14 PM
It's been 20-30 degrees outside, I need to insulate the garage doors.  it took 4 hours for the heater to bring up the temp to tolerable.  trying to stay on top of it.
#53 autotr8er2
autotr8er2
  • 993 posts
Posted 03 January 2014 - 10:55 AM
That spoiler has a ton of sanding involved in it.  Ha. Learned a lot about glassing parts, though.  I really like the drift bumpers running around.  I thought about doing one with a separate bottom lip so when it gets hit, and it will, it can be easily replaced.
#54 autotr8er2
autotr8er2
  • 993 posts
Posted 03 January 2014 - 10:56 AM
#55 Xtreme Industries
Xtreme Industries
  • 1,538 posts
  • Interests:cars
Posted 07 January 2014 - 09:35 AM
i am not a fan of those wheels, sorry. i think the wheels for a starquest need some lip to fit the style of the starquest, those seem too modern/flush to compliment the aggressive styling already associated with the flared starquest design.
1991 BMW 318i - RIP
#56 autotr8er2
autotr8er2
  • 993 posts
Posted 07 January 2014 - 10:34 AM
Can't disagree with that statement.   Hmm, seems I may have to re-think this a bit.  The limitations I'm running into is to go that wide and still tuck under the rear fenders....    They do look like the 370 wheels...
#57 autotr8er2
autotr8er2
  • 993 posts
Posted 07 January 2014 - 05:44 PM
cleaned the engine bay a bit.  A quart of Denatured Alcohol and a Gallon of Elbow grease.
You can see where I used the spot weld cutter.
#58 autotr8er2
autotr8er2
  • 993 posts
Posted 07 January 2014 - 05:47 PM
I want to use this front end offered by the Roadster Shop.  Its their REVO IFS.
#59 Convette
Convette
    I used to driftjunk
  • 4,990 posts
Posted 07 January 2014 - 06:48 PM
dang. You could cut a lot off the front of that car if your going that route.  Whats the $ on that setup?   Quests need dish!  No + offset wheels!
#60 autotr8er2
autotr8er2
  • 993 posts
Posted 07 January 2014 - 11:16 PM
Cutting will be limited to the towers and inner fenders.  The subframe will be reinforced.  I've been stalling on the cutting part.  Waiting on a final decision on whether to pay for the front end or reverse engineer it.
Also tagged with one or more of these keywords: ls, swap
