modern image Posted July 18, 2008 Report Share Posted July 18, 2008 I have an 87 thats been running perfect for years. It died one hot day.....wouldnt start...cooled down for an hour and then started fine. This was the last time. Basically no spark. I have cleaned all related grounds. Swapped (with running car) the coil, distributor, and ignitor. Now im lost, any help would greatly be appreciated!! Link to comment Share on other sites More sharing options...
patra_is_here Posted July 18, 2008 Report Share Posted July 18, 2008 what are you doing to verify there's no spark? Link to comment Share on other sites More sharing options...
Komeuppance Posted July 18, 2008 Report Share Posted July 18, 2008 Heeeeeeeey... southern oregon... Check us out: http://www.nwstarquest.com/phpBB/index.php Won't start hot, sounds like the ignitor box. -Robert Link to comment Share on other sites More sharing options...
modern image Posted July 18, 2008 Author Report Share Posted July 18, 2008 Heeeeeeeey... southern oregon... Check us out: http://www.nwstarquest.com/phpBB/index.php Won't start hot, sounds like the ignitor box. -Robert I pulled the coil wire placed next to ground and crank.....hey robert, read my post just one more time. Link to comment Share on other sites More sharing options...
patra_is_here Posted July 18, 2008 Report Share Posted July 18, 2008 do you have any way of checking to see if the coil is receiving a primary signal? Link to comment Share on other sites More sharing options...
modern image Posted July 18, 2008 Author Report Share Posted July 18, 2008 do you have any way of checking to see if the coil is receiving a primary signal? THE COIL IS GETTING JUICE...ITS THE NEG. SIDE THAT SEEMS FUNNY. INSTEAD OF A FLASHING SIGNAL ON NEG. SIDE...APPEARS TO HAVE A CONSTANT SIGNAL, NOT THE USUAL ON & OFF SIGNAL. Link to comment Share on other sites More sharing options...
Indiana Posted July 18, 2008 Report Share Posted July 18, 2008 two bad ignitors then Link to comment Share on other sites More sharing options...
Shelby Posted July 18, 2008 Report Share Posted July 18, 2008 check the manual for how to test for no spark,, you basicly short across the stator and reluctor poles with a screw driver,, each time the poles are short'd the coil should spark if the pick up is good another test if you have a diff dist is to plug it in and ground the dist houseing to the engine and spin the shaft , the coil should fire as the shaft turns,, but it will do nothing if the dist is not ground'd the igniter is the part that basicly does the pulse,,the pick up just sends a trigger for it to do so if your useing the plastic igniter odds are it's the problem Link to comment Share on other sites More sharing options...
modern image Posted July 18, 2008 Author Report Share Posted July 18, 2008 check the manual for how to test for no spark,, you basicly short across the stator and reluctor poles with a screw driver,, each time the poles are short'd the coil should spark if the pick up is good another test if you have a diff dist is to plug it in and ground the dist houseing to the engine and spin the shaft , the coil should fire as the shaft turns,, but it will do nothing if the dist is not ground'd the igniter is the part that basicly does the pulse,,the pick up just sends a trigger for it to do so if your useing the plastic igniter odds are it's the problem THANKS GUYS!! ILL RUN THOSE TEST. Link to comment Share on other sites More sharing options...
patra_is_here Posted July 18, 2008 Report Share Posted July 18, 2008 you either got a bad ignitor, or the ECU is sending a bad signal to the ignitor. Link to comment Share on other sites More sharing options...
Shelby Posted July 19, 2008 Report Share Posted July 19, 2008 the ecu has little to do with the ign igniter , it's more the igniter sending info to the ecu then the other way arround Link to comment Share on other sites More sharing options...
