CarlosFley Posted August 15, 2014 Report Share Posted August 15, 2014 I searched, but didn't find a definite answer so here i am making a new thread. You guys know that line going from the OVCP nipple to the wastegate? Can I replace with just a simple silicone vacuum line? Or will the heat affect it? Link to comment Share on other sites More sharing options...
speedyquest Posted August 15, 2014 Report Share Posted August 15, 2014 As long as you keep it away from the manifold and hotside of the turbo you should be fine. Guys replace the whole vacuum system with silicon vacuum line all the time. Link to comment Share on other sites More sharing options...
mechengrkj Posted August 15, 2014 Report Share Posted August 15, 2014 As long as you keep it away from the manifold and hotside of the turbo you should be fine. Guys replace the whole vacuum system with silicon vacuum line all the time. I did it about 2 years ago. No problems. Link to comment Share on other sites More sharing options...
CarlosFley Posted August 15, 2014 Author Report Share Posted August 15, 2014 Awesome, that's all I wanted to know. Thanks peeps Link to comment Share on other sites More sharing options...
StarquestRescue Posted August 15, 2014 Report Share Posted August 15, 2014 I do not like the silicon vacume hose. It is slippy and tends to blow off. Tends not to be very oil resistant either. The old fashion rubber hose's seem to stay on much better. Link to comment Share on other sites More sharing options...
TexasQuest Posted August 16, 2014 Report Share Posted August 16, 2014 I'm still using old fashioned rubber vacuum tube. Link to comment Share on other sites More sharing options...
pcristquester Posted August 16, 2014 Report Share Posted August 16, 2014 Yeah, the rubber seems to act like a shrink tube over the connections. Less tendency to slip or pop off with a little pressure Link to comment Share on other sites More sharing options...
importwarrior Posted August 17, 2014 Report Share Posted August 17, 2014 Worst case use zip ties. Link to comment Share on other sites More sharing options...
Edde Posted August 17, 2014 Report Share Posted August 17, 2014 I use rubber with the cloth braid around it. I just keep about 20 feet on hand at all times and replace when it gets hard. Link to comment Share on other sites More sharing options...
