eeaston Posted September 25, 2002 Report Share Posted September 25, 2002 I couldn't find actual specs posted anywhere on the board (Not to say they're not), so I emailed Airtex. Â Results: 38 GPH (=228 lb/hr)=144 liters/hr 115-125 psi Link to comment Share on other sites More sharing options...
rickyturboic Posted September 8, 2003 Report Share Posted September 8, 2003 ??? is it 125 psi constant pressure, or a higest pressure it could get, what is the brand of that pump? I want to know because i have made recent changes in my car fuel sistem an i have a problem maintaining idle speed , i cant get a good idle below 80psi in the fuel sistem (i have 2 accel 83 lbs), but my pump (bosh roller vain) is going dead at 100-125psi. If someone could send me any advice in what fuel pump shoul i get , or someone knows what is my problem I apeciate the advices ! Link to comment Share on other sites More sharing options...
Shelby Posted September 13, 2003 Report Share Posted September 13, 2003 you got to be kiding if you need 80 + lbs of fuel pressure at idle then you have a serious lean problm with your inj's as for a fuel pump go with a bosh CIS pump i don't have a number handy but they do 80lb 24/7 with a max of 150 lb , more then any fuel rquirements you'l ever have , even with 440 cid Link to comment Share on other sites More sharing options...
rickyturboic Posted September 16, 2003 Report Share Posted September 16, 2003 ;D Thanks Shelby for the advise I`ll be getting a new pump very soon and i`ll notify any problem in mi starion. Link to comment Share on other sites More sharing options...
G54Bstore Posted October 14, 2003 Report Share Posted October 14, 2003 can u run that bosch fuelpump with out an upgrade fuel pressure regulator? Link to comment Share on other sites More sharing options...
Kr0nus Posted November 5, 2003 Report Share Posted November 5, 2003 I found the E-2315 fuel pump on CarParts.com, is $160 a good price for it or is there other places I can go. Â I got my fuel pump replaced by pepboys a while ago and I supposedly got a E8000 (*DM thinks they just cleaned off my old one) and I had to pay over $400 when all was said and done...... Link to comment Share on other sites More sharing options...
eeaston Posted December 4, 2003 Author Report Share Posted December 4, 2003 I think I got mine at Autozone for around $110. Link to comment Share on other sites More sharing options...
ZPI28 Posted December 10, 2003 Report Share Posted December 10, 2003 e8000 was $72 from Advance. and the E2315 was $120 here in arkansas.. Steven Link to comment Share on other sites More sharing options...
JAinsworth Posted September 27, 2006 Report Share Posted September 27, 2006 From iminhell: I was bored at work the other day and decided to dig through the Airtex book (fuel pumps). Here is what I found out about the stock pump (replacement pump). (I know some of this is in the FAQ already). Airtex part # E8000 Rollervane construction Inline pump Maximum GPH @ 12 volts = 30 Shut off pressure = 70 - 95 psi Here is what I found for "high volume" pumps (please note that these have not been tested to work) Airtex part # E8151(stock Viper, '92 - '96) Rollervane construction Inline pump Maximum GPH @ 12 volts = 65 Shut off pressure = 150 - 170 psi (my cost - $200.44) Airtex part # E8169 (stock Porsche, '77 - '94 (all)) Rollervane construction Inline pump Maximum GPH @ 12 volts = 70 Shut off pressure = 160 - 180 psi (my cost - $156.25) Airtex part # E8002 (stock '82 - '92 Volvo, '88 - '92 Jaguar) Rollervane construction Inline pump Maximum GPH @ 12 volts = 40 Shut off pressure = 90 - 100 psi (my cost - $75.96) Airtex Part # E2315 (stock '71 - '86 Ford, Mercury, Volvo, Cadillac, BMW) Rollervane construction Inline pump Maximum GPH @ 12 volts = 38 Shut off pressure = 115 - 125 psi (my cost - $78.65) I forgot to write down the Supra pump info, I'll update this when I remember. For my needs/wants I will probally pick up the Porsche pump as I intend to go E-85 and will need the added volume. The "my cost" is only there for referance cost of the pump, I cannot purchase them and resell them, a "walk-in" customer can expect to pay 25% more than the listed prices. Let me know if there are any other pumps you want the same info on. John http://www.starquestclub.com/forums/viewtopic.php?t=27996 Up to you to decide. I got the info from the Aixtex 2005 book at work. John Link to comment Share on other sites More sharing options...
