    Electrical issue
    87TSiStock
    By 87TSiStock,
    Took out my washer fluid reservoir and disconnected everything on the battery and now when i turned it on the first time it worked good and after 30 seconds my wideband and boost gauge and pop ups quit working and now car won't turn over but what is weird is the headlights still work but won't flip open, seat belts don't work. all the fuses inside look good none are broken. Battery is charged and even switched battery's and started (ran perfect) but still no flip ups or gauges. Im stumped at thi
    A/C troubleshooting
    88351wtsi
    By 88351wtsi,
    Probably a stupid question but i have been going thru the FSM troubleshooting because my compressor magnetic clutch is not engaging. The #7 fuse is good. The Clutch relay tests good but what is the FICD relay? Where is it? I cannot find it even with a word search except for in the air conditioning troubleshooting diagnosis 11 breakdown on 24-49. Is it the same relay as the clutch relay and this is the only place where it is referred to as this name? I had system converted to the new refr
    targa tazmania starquest spottings
    CaliConquestAlex
    By CaliConquestAlex,
    Found these while browsing reddit.   https://m.flickr.com/#/photos/callanb/17327299466/in/set-72157650007438023/   https://m.flickr.com/#/photos/callanb/17145861927/in/set-72157650007438023/
    delete
    CaliConquestAlex
    Delete
  • Today's Birthdays
    1. aj_farra
      aj_farra
      (36 years old)
    2. makskylan
      makskylan
      (50 years old)
    No members to show
