- 20 replies
- 2021 views
- 1 reply
- 683 views
- 748 views
Hello from San Bernadino
Would you take the head to a machinist…..
By Mike7447,
If you’re pulling it only to change out the head gasket for an Ajusa, add a set of ARP studs, and replace the timing chain/ eliminate the balance shaft.
the engine has a little over 70k on it, but that still doesn’t change the fact that it has still been on the engine for 35 years.Â
Â
I’d think at the very least have them clean and ck it, touch up the valves replace the seals,….maybe true up the head mating surface?
Seems logical to me.
On the other hand, I have heard that tig
Mps/ isc ground
By Logan0296,
Hey,
This is my first post but have been using the fourms for awhile to help with problems. But anyways, I'm trying to figure out why my isc only moves when the car cranks over. In the on position, it sits at .04 volts which indicates a problem. Out of options, I probed the harness connector with the ecu unplugged, and it appears that isc plunger ground is grounding to the mps signal wire. I looked at the electrical diagram and noticed those two wires go to the ecu without intersecting. Is
AC/Alternator bracket
By Mech,
Looking for the large heavy bracket that holds the AC compressor and the alternator to the engine. Also need the AC tensioner pulley that bolts to the left side of the head.
