- 935 views
- 6 replies
- 899 views
- 13 replies
- 1364 views
FS: M28 complete head (needs valve job) $150 shipped
By movin on,
I have an M28 head that needs a valve job due to a slight seat warp on two seats for the intake valves. This head was looked at by a machinist and I have his contact information and the receipt from him if you would like to talk to him. The seats are marked in the photos. I am not sure of the exact flatness of the head. I knew when I brought it in before he cleaned it, it was .006" right by the #3 cylinder. He said it cleaned up well and that it is more flat after being cleaned. I would re
Happy Birthday Crazy larry!
Mirror Mirror
By importwarrior,
the driver door mirror rattles or vibrates bad when driving. the passenger side is perfect. is there a way or any suggestions on how to tighten it up to stop the vibrating. the glass mirror is moving the mount is fine and solid. when i move or adjust the mirror all is fine. its just loose in there.
manifolds ebay vs treadstone
By kaaos,
http://www.treadston... Turbo Manifold can someone recommend this or the ebay stainless manifold? http://www.ebay.com/...c91ef1a&vxp=mtr any recommendations on ebay turbos? Rebuilding engine now, shortblock is together. assembling head still. wisecos 8:1 njv head stock valves mild porting.valve job 87 quest with 89 ecu bsek 240mm flywheel. will be running megasquirt or maf translator aiming for 300? + hp stock cam until i get it running. how much hp could i get with a s16g,since the 16g w
