- 1058 views
- 7 replies
- 947 views
- 903 views
- 5628 views
Why do I need the passing control relay?
By Mike7447,
I figured out my headlight issue.
#1. I am an idiot.
i had the male headlight harness plugged into the wrong female socket.
unfortunately, I managed to kill the passing relay while trying to bypass junk.
if all this thing does, is raise the headlight doors and allow me to flash someone I intend to pass, then I can forego using it. It appears a new one is about 100 bucks.
i know I can jumper headlight function simply by combining the blue/red, and the blue/yellow wire that
No headlights, TS, Brake lights…fog lights
By Mike7447,
I’m going crazy trying to determine the issue. Dash is currently out, but I’ve got the cluster switches and multifunction switch plugged in.
the passing control relay under the dash is plugged in. The instrument panel is unplugged, and cannot be plugged in, I’ve hacked it up to customize the instrument cluster.
the issue is when I turn on the headlights, the doors raise, but no headlights, or passing control pop-up.
Interior lights, hazards, running and tail lights work.
iv
Chad exhaust
By Evoz17,
Does anyone know if Chad is still around doing exhaust manifolds?
5.0 engine swap - Cooling issues
By conquestcobra,
I did a 5.0 engine/T5 trans swap a long time ago and have always had cooling issues. Can anyone who has done a similar engine swap tell me what radiator they used and how/where they mounted it? Any help would be appreciated. Thank you.
P.S. I tried to post this to the Engine Swappers topic but it wouldnt let me choose that as a topic.
