- 6 replies
- 639 views
- 6 replies
- 541 views
- 25 replies
- 4074 views
- 305 views
Need a 86 hood release handle
By 87redcat,
Hey guys, I got an 86 Flatty with red interior and in need of a hood release cable and the pull handle to pop the hood. previous owner had it all torn up. Help
mas question
By Power ram 50 turbo,
Ok guys wanting to ditch the stock mass what a good one to go with I'm getting ready to go on the dyno and just need to finish up some loose Ends here is a list of the mods so far 19c turbo. Set at 15 lbs 850 & 1150 lsp Injectors adjustable fpr set at 44lbs walbro 255 & 52mm throttle body over size Valves bulit bottom end 2.5 in exhaust no cats the truck ran great in stock form No problems at all and runs great now but going for max hp power with this set up And I'm thinking the stock
86" Starion 2.0 TURBO EX intercooled
By Tomica93,
here, finally i have one Starion too, iam a Mitsu lover, this is my 11Mitsubishi lot of them are old, but very rare , iam from Zagreb, Croatia, small country near Italy ana Hungary so, i found this car in some village, its in pretty bad shape, but still runs, i paid for it 450$ engine is 2.0Turbo Eci Turbo with 2injectors on the top, 170hp flatty intercooled version, but has KKK turbine on it EX - luxury equipt A/C ABS power steering vented front and rear discs Turbo rear lip Vestatec Turbo
WTB Manual Pedals, Bracket for Clutch Master, Clutch Pedal Bracket, Hosing to Slave (5speed Swap)
By Rachet,
I need all the pieces for a 5speed swap. So far I have a clutch, flywheel, transmission, driveshaft, interior trim. I need the clutch master bracket and bolts, the clutch reservoir, any lines, the fork dust boot, the trans tunnel boot, and the pedals. The bracket that the clutch pedal attaches to is also sweet if you can drill off the tac welds.
