- 20 replies
- 1685 views
- 1 reply
- 704 views
- 4 replies
- 1670 views
- 884 views
remote oil pressure mount Pics Added
By importwarrior,
i installed a oil pressure gauge in the side of the block and mounted the sender on the fire wall. i got the Kunigawa -4 A/N by 1/8 BSPT ( tapered ) http://www.ebay.com/...6-/181900298482 then ordered the 4 an hose from Pegasus racing pre-made. can get them from anywhere. just measure the length you need and get the closest to your needs it is PTFE teflon lined SS hose https://www.pegasusa...n.asp?Product=4 1/8 NPT Female to -4 A/N adapter http://www.summitrac...04erl/overview/ dep
Left Foot Rest Floor "fixed Pedal" bolt needed - thread size?
By mstieg,
The rubber foot rest to the left of the clutch pedal. Solid mount to the floor, well not anymore at least. There's a bolt that goes into the side of the frame. The thread on mine is so far shot I can't tell what size and pitch it is. Please help so I can easily get a replacement bolt. Thanks in advance.
What fuel pressure you guys running?
By Preludedude,
Just got my spa turbo afpr installed. I don't know what stock pressure is but I have it set at 42lbs at idle currently. I have 650/950 Delphis from Brian at Lower Shores.... What should it be set at approx? I know it depends on your setup...
NEED stock TURBO
By fromji,
Mine has oil leaking and make smoke when I release gas pedal after psing hard the gas pedal. e mail me to fromji@hotmail.com Thanks,
