- 16 replies
- 2359 views
- 1536 views
- 18 replies
- 2368 views
89 Red.Conquest.TSi.Runs&Drives.Price Cut!!!
By 89redbeauty,
hi guys, I have for sale a 1989 Chrysler conquest TSI. It's red in color and has 169000 miles. 2.6 turbo 5 speed with LSD rear end. 5 speed new clutch, non jet valve head, ARP head studs, one millimeter oversized valves, mechanical lifters, 1g DSM MAF to run more boost, cat back exhaust, coilovers, HKS blow off valve, front mount intercooler, polish valve cover, full gages including a boost gauge integrated into the factory cluste. Runs and drives fine the only thing it needs I believe is eithe
Cam Relationships
By scott87star,
Time to add something to the cam forums. Y'all have heard the terms, here's the math that defines the cam parameters. First, the definitions. Overlap: period in crank degrees when both intake and exhaust valves are off the seat. Duration: period in crank degrees when one valve is off the seat (seat to seat duration) or at a given lift value (0.050" typical). LCA: lobe centerline angle or the angle in crank degrees between the peak of the intake lobe and the peak of the exhaust lobe. Note
Can td06 fit in starion exhaust housing?
By boostinmini,
Looking at td06 turbo wondering if I got the Starion exhaust housing machined would it fit? Or td06 center sections are just to big?
