- 8 replies
- 3093 views
- 526 views
- 1046 views
- 11 replies
- 1207 views
85.5 starion won't run under load
By 383chevelle,
I am in the process of talking my dad through fixing up an 85.5 starion that is not running well. The car will start and idle fine all day long. Before it fully warms up you can drive it around and it runs good, but once it reaches operating temp when the engine is put under any load at all it will die. We have recently put a new tank in it plus new injectors, new fuel pump and filters.The vacuum lines have been changed out using the replace one at a time method. I told him this would be a diffi
Side Markers/Scuttle Panels/Cover Plates
By Guest GeeDee,
Hello everyone I need the following parts sent over to the UK if possible? 1 pair of side markers (or the blanks that euro flatties have) Both plastic scuttle panels Bell housing cover plate (between engine block and transmission) Metal bulk head cover plate (sits behind the brake master cylinder servo) Any help greatly appreciated! Cheers Greg
Bolt on high ouput alternator
By tcroson,
I have a bolt on(kia optima I think) 130A alternator It bolts on, but the pulley will need swapped out to your original one. I may have the pigtail, but if not, any junkyard, any kia. This was used for a garage test only, never on the street. 125+shipping. http://imageshack.com/a/img843/5277/ftd4.jpg http://imageshack.com/a/img835/7080/v7id.jpg
Fresh bottom end ready for assembly. New pistons/rings,etc all balanced.
By tcroson,
Just picked from the machine shop last night. Fully balanced, not lightened. All brand new unless noted. PACKAGE DEAL. New Hypercast pistons(whatever DAD sells) 1mm over New Hastings ring set 1mm over REBUILT rod set with ARP rod bolts and the new pistons installed. Good Turbo crankshaft-STOCK, NEVER GROUND!!!! Fresh polish ready to go. Block , bored over 1mm, decked,checked for cracks,etc. tanked, ready to painted New freeze plug set All new dowels for block New timing kit-everything kit, gea
