- 4 replies
- 614 views
- 18 replies
- 8320 views
- 25 replies
- 3114 views
Radio...did I fry it?
By dtownmikebrown,
I've got a stock radio inside my '87. ' A few months ago, almost everything was working fine. I had the radio on and when my friend opened the passenger door it turned off. Later I found out that I had the trickle charger hooked up backwards. While I had the dash out of the car to clean up after the mice, I popped the bottom panel off of the head unit and found that one of the fuses was blown. I replaced the fuse. Since then I've replaced all the fusible links and serviced all the grounds. N
4g63 6 bolt vs 7 bolt question
By starion1991,
I've got a quick question about 4g63s I've got a buddy of mine selling me 2 complete motor sets out of eclipses. First one is a automatic 6 bolt out of a 1990 talon, second one is a 5spd 7 bolt out of a 95 second gen eclipse. My question is would the same bell housing adaptor for a r154 bolt up to both motors, or would I need one the 6 bolt and one for the 7 Only reason I'm asking is id like to drop in the 7 bolt for now, while I build the 6 bolt up.
PLEASE DELETE - DOUBLE POST
88 parts, some performance
By noskillz,
Radiator with fans-75+ shipping Fidanza flywheel, less than 500 miles on itr- 200 shipped Stock 88 flywheel-25+ shipping 12a turbo, good shape, minor shaft play- 65+ Shipping Good 88 Trans- $125+ shipping Hopefully motor and everything will be pulled this week, so I will have more details. The rear main seal and oil pan gasket were just replaced on motor along with the clutch and flywheel. Also have a couple of g54b cranks, and another 88 Trans that pops out of third, every othe
