    056700-4840 Relay
    perferan
    By perferan,
    Hey guys, does anyone have in your car the relay 056700-4840 or the relay MB140972? I need the wiring diagram.   Thanks and best regards.
    88/89 Trans Oil Cooler
    helluvaengr
    By helluvaengr,
    Followed the Newbie steps to a T and now my transmission oil cooler leaks! Prefer an above average to excellent unit for replacement. Would also like "S" hoses and a few clamps.
    Automatic Transmission Overdrive Issue
    Guest 87redstar
    By Guest 87redstar,
    OD stopped working in a 87 tsi the other day. Metal hard vac line to the trans had a leak so I cut part of it off and replaced both rubber lines. Would a leak on that line stop the od from working? Noticed if you pull the relay from under the dash you can hear the click from the solenoid on the trans when you cycle the OD button. Already tried thermostat housing sensor by grounding the one wire that goes to the trans, checked the back fuse and still no luck. Havent test driven yet since fixing t
    Cabot AR Pick N Pull. flatty
    MikeMeyerhoff
    By MikeMeyerhoff,
    Pick N pull has a white 85 Starion there. Its white and the pic did not show it to be wrecked. Didn't look like a bad car overall. Couldn't tell interior color.   If you plan to go, please let me know.   mm
  • Today's Birthdays
    1. ko929
      ko929
      (53 years old)
    No members to show
