    Just bought my first Starquest
    devilsfutbol17
    By devilsfutbol17,
    I just bought an 88 Conquest TSi SHP that currently doesn't run. I'm eager to learn as much as I can from these forums and will hopefully get the car running. Under the hood its kind of rough, and the interior is pretty stiff. Besides it not running, I've got a few other bugs I need to get worked out, but for the moment my main objective is getting it to start up.   I'm more of a 4g63 guy as I've owned a couple DSMs and Galant VR-4s, so some day this car will probably see a 4g63 swap. Currently
    Solid U-Joints Get Them While You Can
    ucw458
    By ucw458,
    Beck Arnely part # 1020429 is the SOLID and strongest u-joint for a SQ. Not drilled for a zerk fitting.   Only 3 left at the clearance price of $3.82 and only 6 left at regular price of $11.92     The Rockford constant velocity part # K1516 also crosses to the beck arnely part number as a carquest only part #. So I'm betting carquest reboxed the beck arnely joint. There are 16 of those left at the clearance price of $3.82         I cannot find these joints anywhere else. As far as I know the
    Recommended shops?
    jmmy
    By jmmy,
    We all like to work on our cars ourselves, but sometimes we don't have the time or tools to do so. Sometimes it's easier to just bring it into a shop. Searching online for a local place that knows Starions and Conquests is basicly fruitless.   Perhaps you own or work at one, or have good word about a G54b guru somewhere.     What are shops in your area that you're confident in bringing your car into?       edit: It's great that you take pride in working on your car yourself, but if you're here t
    Magna MPI won't fit
    RWDAddict
    By RWDAddict,
    So I got an unmodded intake from a member on here. Sat on it for a while and now going to install it. Took it to the machine shop buddy i know to get the flanges changed and the coolant passage swapped over. The other bonus is I have an M28 cast head which has the larger coolant passage so I don't need to modify that. All good things.   Well the issue i'm running into now is the lower intake plunum won't sit flush against the head. It's hitting the top of the steering box. Even to get to this p
  • Today's Birthdays
    1. J_Copeland
      J_Copeland
      (61 years old)
    2. sail4.0
      sail4.0
      (76 years old)
    No members to show
