- 15 replies
- 4646 views
- 17 replies
- 2114 views
- 8 replies
- 1568 views
- 847 views
Revolution Big Brake Kit
By TexasQuest,
Has anyone used the Revolution Big Brake Kit on their car? If so, how do you like it? They have 2 sizes, 330mm & 302mm. I'm assuming the smaller one is to fit the factory wheels?
Mitsubishi Starion Big Brake Kit - Sport (revolutionbrake.com)
Looking for a Vacuum Advance... 1987
By FBS,
Hi.. so I have been slowly going through everyones suggestions trying to see whats going on.... I have discovered that I have no vacuum advance... I hooked up a vacuum pump to it and I have no reading on the dial...I tried it multiple times. Makes sense why it is running the way it does . I have a brand new distributor in the box but it has no vacuum advance on it.. not sure why.. I looked online at part stores... funny Napa says they have one for a 86 with the same part number for an 87
A couple of pictures of the car
By FBS,
Hi I thought to share a couple of pictures I just took.. I got the fuel problem fixed... need to work on the ISC and TPS.... thanks for all your help...
AC parts everything $20.00 pick up 18092 PA
By BKB94,
Every part $20 each, NO SHIPPING
Condensers Qty2
condenser fan Qty1 TESTED
Liquid line from dryer to crossmember bolts Qty2
Gas Hard line from evaporator to firewall Qty1
Gas Hard line from firewall to compressor Qty2
Gas line from compressor to condenser Qty1
