- 13 replies
- 833 views
- 10 replies
- 1040 views
- 6 replies
- 766 views
- 14 replies
- 1331 views
New guy super happy 2b here,in Colorado....
By 1stworks,
Well I got my 86 station last week.I flew out to St Louis and drove it back to Colorado.the car has 59k and in really good condition. It was kinda a impulse buy but I really wanted it.I have another sports car but have put too many Miles on it + it has no heat.....I found this one on bring a trailer. Anyway s thanks for having me! To do list Install new injection connectors Oil pan gasket\front crank seal Clean intake\throttle body\injectors Inspect \diagnosis drive line clunk "torque tube mou
Check out this mint Cordia
By Fanta,
Was on BAT - only 30k on the clock! http://raleigh.craigslist.org/cto/4734321577.html
How long is a 6 bolt cv shaft
By ucw458,
I'm hoping someone has a cv shaft laying out that they can throw a tape measure on and get a rough length. Doesn't have to be precise. I would measure my spare but it's buried behind alot of stuff in the cubby hole under the water heater. The reason I need the measurement is I have an old vietnam era 50 cal night vision scope case. It may be the perfect size to put a pair of CV shafts and spare parts in for long trips. Sadly the scope is long gone. http://i463.photobucket.com/albums/qq
new here im loosing it guys
By cristarion,
I posted a topic before saying that my car only runs for 20 sec, this is what I figured out and some of the issues, -The fuel pump only turns on when cranking -Too much fuel when cranking I think both injectors are working at the same time. (just ordered new ones) -Engine starts only if I take the FPR off then it dies -If I run 12 volt to fuel pump wire still turns off after 20 sec -It stays on only if I apply 12 volts to fuel pump wire and if I disconnect the pipe from the turbo, it wont idle
