- 10 replies
- 1407 views
- 6 replies
- 933 views
- 1139 views
- 6 replies
- 1368 views
Coolant high temp sensor that shuts down the A/C
By BandY,
Can someone help me learn where to buy this part? The chain stores don't even list the sensor. It's usually the highest sensor in the thermostat housing, I'm pretty sure. The lowest is for the gauge, and the other is the coolant temperature sensor. The one I'm referring to has very small threads, and it's mostly made of brass, with one single plug. If the engine temperature gets too high, this sensor stops the ground to the compressor, and shuts down the a/c. Thanks for the help.
How to rebuild cv halfshafts?
By jeph_tsi,
Curious, with our axles and many others being nla, is there any good place to get parts to rebuild? I need to rebuild an axle that is hard to find, non sq.
new starion owner (for the second time) could use a little help
By justin240,
alright so just to start off, i finally bought a second starion, i had one a few years ago, bought it, put a clutch in it the next weekend, and then lost my job the weekend after that and had to sell it (been sad about it ever since) so after a few years i finally stumbled back asswards into a second one, this one is an 87 last one was a 86 both widebodys (love the look) so just to start with the list i have recieved on this particular car as told from the previous owner, my research has pro
225mm flywheel redrill to 240mm resurface and lightening
By 83stariontravis,
Gauging interest on flywheel machining would shoot for 10 flywheels but 20 would be nice. I have a couple sitting here but would need all the cores here aside from my two spares before I run them. One of my spares I will run for an example picture. For my 83 I re-drilled my stock flywheel with the 225mm pattern to accept the 240mm pressure plate and am very happy with how the clutch feels now. I also took the mass off of the back down some lowering the weight of the flywheel from about 35
