- 4 replies
- 481 views
- 16 replies
- 1806 views
- 441 views
O2 sensor wire Voltage
By Conquest Junki,
Hey I'm just wondering if anyone can tell me if your supposed to get a 1 Volt output reading at the O2 sensor wire coming from the ECU when the ignition switch is on but the engine is cold? I know the FSM says to check it after engine is warm and you have drove for a while but my car is running super lean and I don't want to drive it like it is. I have installed a new single wire O2 and I just installed a 3 wire O2 and I'm still getting a O2 sensor code even after taking off the negative battery
Primary and Secondary cooling fans cut in temperature
By FBS,
Hi everyone, things are going well with the car. Summer is near and I am planning on taking a bit of a drive. The cooling system has been flushed recently, car does not appear to have any overheating problems. There is one thing though that bothers me. I have a long steep 1 mile driveway. Usually by the time I get to the top, temp needle is half way up and #1 cooling fan is on.
i have yet to see the secondary fan cut in. I check the fan motor and the motor relay and both work perfectly
BMW Rotors from 12" OTG BBK Kit
By tux,
Does anyone know which BMW rotors Oscar-The-Grouch used on his 12" BBK kit?
