quest96
Everything posted by quest96
sold.
No thanks. The only trade I might consider is a jeep wrangler TJ.
I have a 87 conquest with a 4g64 swap. the engine has wiseco pistons, eagle rods, arp studs, comp cams, crower springs, SDS stand alone fuel & spark management, turbonetics 50 trim turbo, turbonetics manifold, tial external wastegate, devils own progesive methenol injection, aem widband O2, spec 3+ clutch, stock 89 5 speed transmission. The body is nice & interior is really nice. It has 90,000 mi on the car & the engine has about 2000 mi on it. New ball joints & brakes. The car ran 12.88 @ 108mph at 15lbs of boost. $4500 if you have any questions you can call or text 570-751-8303. Hazleton Pa.
Anyone have a T3T4 rebuild kit or just the turbine seal they want to sell. I'm in Pa. Just trying to get the car going by the weekend. Thanks....
MEET AT MY HOUSE!!!!!!!! nepa,ny.nj.de,md
quest96 replied to starquestJOE's topic in StarQuest Meet Planner
hey guys, I like to stop by. I'm in hazlton, my cars up and running. Probrably around 12 or 1 I can be there for.Anyone coming have an old clutch disc 240mm laying around I could pick up from them. I'm having some issues with mine I think the disc is to heavy. I dont care what kind it is, I just want to see if it shifts any better.. Thanks... -
send me your email. I never had any luck with pics on here.....
is the coil good? Those ford coils were known for going bad. I can send u a factory diagram for edis if u need. just let me know what year and model it came from... Ps when is the meet at joe's.. i'm in hazleton...
Do you have a fast idle solenoid? I used one from an early injection vw jetta, they have a dual solenoid I just seperated them and used one. I can check my start up #'s. Do you have a wideband for tuning?
Hey mighty max who's doing your a500 trans and how much power will it hold? I've got a 4g64 thats making some power, maybe 400 plus and i'm thinking of putting an auto in. I was thinking of a built 700r and bills adapter but this might be an option. Thanks for any info....
Has anyone put a 700r4 behind a widblock or 2.6? My question is if it will clear the trans tunnel in the car. It is a stick car and I plan on using one of bills adapters. I've seen the th350 but I just want to be safe before I get all the parts and have to do major reconstruction of the tunnel. Thanks.....
I pulled the trans and I found the input shaft was dry. I guess I forgot to clean it and lube it when I did the swap. It works good now. I'm taking it to the track tommorow so we'll see what it does... Thanks for the help...
Is anyone running the spec3+ cluch? I have a swapped 4g64 with an 88 trans and a 3+ clutch. It seems like the clutch disc is hanging up. When you push the pedal the clutch drags for a few seconds when your coming to a stop then it releases and is fine. It does the same at idle when you go to put it in gear it wont go in until you push on the shifter a little and you can hear the disc spin when it releases. I had a centerforce before and had no problems. I even changed the slave cylinder and it didn't help. It seems like the disc doesn't want to release from the flywheel. the disc is pretty heavy I wonder if it isn't sticing. I'm considering going down one step to the spec3 i'm just worried that it wont hold. Thanks for any input.... P.S. It runs like an animal.
I just finished my 2.4 mitsu truck block 4g64. and dohc head.. didn't really get to drive it much...
I have a wedding to go to on sat. I just finished my 4g64 swap and wanted to bring it down on sun...
anyone going sunday?
MPI with Vacuum Advance
quest96 replied to autoxer's topic in MPI/Standalone Trials and Tribulations
I wouldn't use the caravan igniter. I tried that and had nothing but trouble. It would run ok but I think I had some isses under load. I went back to the stock igniter with a msd and it worked great. You don't need the msd but you can use it with the igniter. -
If you look in the pic that james sent, you'll see his igniter box in the pic. That's probrably why his works. As for as ported vacum that just means before the throttle plate. -
Did you eliminate the stock igniter and use the 2 wires from the dist. directly to the wires on the msd? I was only runnig feul at one time and I tried it that way and it didn't work. So I used the stock igniter along with the msd and the tach adapter for the tachometer. I think it has to do with the dwell. Give it a try. I think there was a few diagrams on here. Hope this helps... -
Lots of stock stuff for sale. 20+ cars worth.. whatcha need?
quest96 replied to Kreal's topic in Parts for sale
do you have a 240mm flywheel? -
Do you have a manual 240mm flywheel? If so how much. Thanks....
Anyone have a 240mm flywheel?
hazleton
anybody have a 88-89 5speed in N.E. Pa.....
thanks that will work..
Anyone have a stock flywheel bolt they could measure and let me know the length from the inside of the head. Thanks....
