Everything posted by maximum_overdrive
need good 12a turbo will pay friday morning. will need shipped ASAP to get my daily on the road. dont really have the money to spare at the moment so not looking to spend over $250 shipped, less if possible. thanks
as the title says i need a good distributor
the whole time i have owned this car it has idled a little rough but it drive perfect. i chased my tail trying to fix it but gave up. yesterday it started to run really rough at idle and when ever i hold it at any rpm. but if i rev it its fine. i pulled the cap and found my distributor shaft has a fair amount of play could this be my problem? video http://vid134.photob...t_300ZX/001.mp4
tail light sold
i dont want to sell it out from under him but if he doesn't get back to me tomorrow its yours.
i have the maf off my car worked fine but went to a 1g maf. the honey comb is bent in one spot but it worked fine.i cant find any for sale to price it from so ,$50 shippedalso have a drivers side tail light no cracks but is scuffed a little could be wet sanded and polished up. $25 shipped.http://i134.photobucket.com/albums/q104/Drift_300ZX/003_1.jpghttp://i134.photobucket.com/albums/q104/Drift_300ZX/001_2.jpghttp://i134.photobucket.com/albums/q104/Drift_300ZX/002_2.jpghttp://i134.photobucket.com/albums/q104/Drift_300ZX/004_2.jpg
Ford or Lincoln Mark 8 radiator fan information
maximum_overdrive replied to importwarrior's topic in Just plain ol' B.S.
the mark 8 fans are no joke, on low they are 3500 cfm on high they are 5000 cfm- 11 replies
Best Double-Din aftermarket stereo deck?
maximum_overdrive replied to mstieg's topic in Just plain ol' B.S.
i had that one in my maxima and really liked it. the only problem is the lighted parts of it are really bright at night. -
I learned to drive a manual in this vehicle...
maximum_overdrive replied to pcristquester's topic in Just plain ol' B.S.
thats where i got the name from . it was one of my favorite movies as a kid. -
moog outer tie rod ends wrong?
maximum_overdrive replied to maximum_overdrive's topic in Virtual Mechanic
its for mighty max`s and monteros and 89 only conquest.someone got some misinformation somewhere. lol -
that looks like it, rock auto has the part numbers wrong for the 89 conquest. if i use 88 it gives me the correct one. thanks. -
i got a moog outer tie rod end ( es2246l ) from rock auto and its about 2-3 inches to short.am i missing something? http://g03.s.alicdn.com/kf/HTB1md5MFFXXXXc_aFXXq6xXFXXXK/220977364/HTB1md5MFFXXXXc_aFXXq6xXFXXXK.jpg
1990 nissan maxima, rare 5 speed. i was 14 (2004)and it wad first time i ever drove a car. killed it once and was golden after that. that poor car went through a fresh water flood in 2003. water all the way up to the roof. we changed the fluids and drained the water from the engine . after a few weeks of sitting it started right up and my dad drove it until 2006 and put 25,xxx miles on it post flood. i have had 2 other 3rd gen maxima 5 speeds , something about those cars keeps dragging me back. http://i134.photobucket.com/albums/q104/Drift_300ZX/maxima/maxima015.jpg -
i need a steering box in good shape ,would prefer if it has the pitman arm still on it so i dont have to remove mine. cant pay until friday (27th). my steering box is dead, it pulls to the right , its harder to turn left than right and has 6" of play (good coupler) and leaks everywhere. i have played with the lash adjustment screw but it only helped a little and it just keeps getting worse. its getting to sketchy to drive on the highway i would rather gamble with a used one from a starquester than gamble with a "rebuilt" one.
premium is 2.32 here
what about a ka24 from a 240sx , people are almost giving them away when they swap to sr20s, or mini truck engines should be cheap , get a 22re from a toyota pickup.
fuel injector clinic stock replacement injectors
maximum_overdrive replied to maximum_overdrive's topic in Parts for sale
sold -
$125 shipped -
turns out it was a bad ignitor , it failed yesterday i replaced it with a gm hei unit and the miss went away.but, i was wrong about my vac advance tho i can now suck air from it. where can i get one from to be sure i get a turbo one?
got the ignitor replaced, works great and it fixed a misfire issue i had aswell. i mounted it inside the factory ignitor i just hope the box works as a decent heatsink http://i134.photobucket.com/albums/q104/Drift_300ZX/002-4.jpg http://i134.photobucket.com/albums/q104/Drift_300ZX/003-3.jpg
i think i have narrowed it down the the ignitor, cant you replace it with a gm hei ignitor? if so does anyone have a write up on that? thanks.
it doesn't spray any fuel and i just found that the tach doesn't move at all ether.
today when i started my car to warm it up it ran for 30 seconds and died and will not restart. it has done this 2 other times but it fired back up immediately . im getting no spark, got 12v to coil+, jumped the fuel pump wire and got voltage at it. it has a msd coil and factory says it should ohm out at .7 primary and 4.5k secondary i got 1.3 primary and 4.8k secondary its off but i dont think it would keep it from running. is it a bad dizzy?
did a leak test and all is good, temp sensor was reading 238 ohms at full temp,vac advance has its own line and its good,the accordion hose was replaced when i did the 1g maf swap and its all new.
