KevinL87tsi
Everything posted by KevinL87tsi
Here is an HKS EVC EZ I'm selling. I sold my car and will be posting my extra stuff on ebay: http://www.ebay.com/itm/321082915890?item=321082915890&viewitem=&vxp=mtr Opened just to verify contents, and take these pics
- boost
- controller
(and 6 more)
Tagged with:
I am looking for an 88/89 transmission in good working condition. My car is pulling hard and the transmission is one of the weak links (87). Would like pics or someone local to central tx. Thanks! -Kev
knock/detonation sensor watertight connector
KevinL87tsi replied to KevinL87tsi's topic in Virtual Mechanic
Now that radioshack sells computers they don't have a 10th the selection they did even 10 years ago. I looked at frys electronics with no luck. About to replace both connectors with something else, but a new knock sensor has the same thing. It looks like someone already recrimped this terminal... It is smashed -
Noone knows? I still can't find part numbers in the forums or the shop manual. :deadhorse: -
EXHAUST: what to buy? is TEP really garbage?
KevinL87tsi replied to gwadd85's topic in Virtual Mechanic
I have tep downpipe installed with no fit problems -
My wiring harness to the knock/detonation sensor was messed up (wires broken) on the wire harness side. I pulled the crimp on blade wire pins (2) out of the connector. The signal wire was still attached but needs to be redone. The wire attached to the shielding i assume for ground, was broken at the pin. So basically i need new crimp on terminals for the watertight connector on the male end. I cannot find these anywhere. I went to several auto parts stores and had every guy in the stores confused about what it was, or they had no idea where to get one like it. They showed me their catalog and i was able to find similar watertight connector terminals, but they were either too short or didnt have the same clip. Does anyone have a part number or supplier who can get these? I will probably buy 25 of em if i find where to buy since these type of connectors are all over the car (slight exaggeration). Also if anyone has pics of their rewire experiences with the harness on this car, let me know. There are a few other areas that need attention. Thanks in advance, Kev
This is how i hooked up mine years ago, (drilled out stock pcv to allow it to restrict airflow somewhat, small kv after that then intake) Krankvent FAQ by Boosted One never really had a prob with the setup until this hose blew off... i didn't think it took full boost or i would have replaced it a long time ago and bought new clamps.. good thing i wasnt pushing the car, just got it running again after a few months of sitting, noticed the hose popping off after short drives around the neighborhood. Thanks for the info guys
Isn't the point of the krankvent to eliminate the oem pcv? It is a heavy duty one way check valve that only allows pressure from under the valvecover to vent out, nothing can get in. Is there a reason to use an oem pcv instead? New knowledge gained by the boards? I can understand getting another hose to hook to the front krankvent... So this hose would see 15psi if i was running 15psi boost? Guess i had better get new hose clamps and a new hose... Would the crankcase bleed off pressure into the intake under an intake vaccum situation only? :confused0024: Thanks
Its been a long time since i've worked on the quest, please refresh my memory. This port, which a hose from the pcv ran to (my krankvent), seems to be blowing off under boost (not for sure, but hearing air rushing under boost from somewhere, although it is definitely blowing off). Can boost reach this large port? http://www.longblogs.com/longblogs/gallery/conquest/intake%20port.jpg Dirty i know, any advice on what to clean this with would be helpful too, although i havent really tried to clean it either Thanks
FS: 87 conquest tsi austin, texas - runs, many mods *PICS Added*
KevinL87tsi replied to KevinL87tsi's topic in Cars for sale
All still available, I have several people interested in the tail lights and hood. As for the car, any reasonable offer will be considered. pic of taillights: http://www.longblogs.com/quest/starion-tails.jpg -
prices: tokico shocks $300 for the set of 4 (2 front 2 rear) poly engine mounts $70 (pair) 2 hydraulic cylinder heads ($50 each) starion tail lights $120 for the pair 83 hood $250 hks evc ez $200 shipping not included, will work with you on the cheapest or best shipping method everything is negotiable, especially to those who will pick them up in person anything i make on these parts, i knock off the price of the car, since all of this would otherwise go with the car -
i want to sell the car as one whole unit, however i do have some parts that arent installed on the car that i would be willing to sell separate, otherwise they will be included with the car: off the top of my head: new in box tokico shocks polyurethane engine mounts 2 hydraulic cylinder heads that need work, one had a crack between valves patched 1 set of starion tail lights in mint condition 83 scoop hood (black) (original non-fiberglass) hks evc boost controller -
Selling car after 8 great years of ownership. Black on black 1987 conquest tsi 5 speed & sunroof with a 19c turbo, braided steel feed line, fidanza flywheel, hks bypass valve, tep ovcp, tep cam (274?), new tep head/valves, arp head bolts, autometer boost gauge in stock location, a/f ratio gauge, 3 wire o2 sensor, tep 2.5" mandrel bent downpipe, 2.5" exhaust w/ high flow cat & walker ultraflow 3" muffler with 3" chrome tip, arp main bolts, shot peened rods, je forged pistons, total seal rings, crankvent valves, msd coil & red wires, braided steel brake lines, metallic brake pads, slotted rotors, stedebani polyurethane transmission mount, 89 ecu, k&n air filter (old style, can temporarily removed and held together with bailing wire, still have can), and it includes the following parts: new 2 gauge a pillar pod new in box tokico shocks new in box hks evc boost controller new in box stock fuel filter assembly new emergency brake cables new cyberdyne digital oil pressure gauge & sending unit original 83 scooped hood (original black) mint condition starion taillights spare set of 7" front and 8" rear wheels 2 hydraulic cylinder heads that need work I have a new 88-89 style front air dam at a friends house that i can get as well, was painted once but after sitting next to other cars being painted, it had uneven overspray so it will need to be repainted. it has never been installed on a car. Car has been sitting a few months due to power steering problem, pump has been replaced, it appears to be leak in the line, or it just needs to be bled properly.. haven't had time to do anything besides replace the pump. Wouldn't start as of this week, gas is stale, i pumped most of it out and it wouldn't even run in a mower... shelf life of gas these days seems to be diminishing Just married and selling off all of my expensive toys, $3500 OBO takes it all. Located in North austin http://www.longblogs.com/quest/in_garage.jpg old pic showing 83 hood: http://www.longblogs.com/quest/83_hood.JPG http://www.longblogs.com/quest/3.jpg http://www.longblogs.com/quest/in_garage2.jpg http://www.longblogs.com/quest/engine.jpg forgot to mention, it also has a race clutch
nice rack
the scary part is the z06's run mid 12's stock... and few starquests run it consistantly... i hope we can continue to compete with newer stock cars.. im going all out this build to make sure im a few car lengths ahead of the vettes
i learned the hard way.. when they asked ME to go into detail by what i mean when i asked them to "bush the small ends of my rods for floating wrist pins"... Â i should have turned and run, somehow they convinced me they could be trusted.. i guess after i spoke to their manager.... but everyone in austin recommended "quality engine exchange" as a great machine shop until the machined my crank out of spec and i spun a bearing.. now everyone says.. "yeah that place has a bad reputation".. and im like wt...... 3 months ago you recommended them to me. Â Good machine shop in austin is very hard to come by. Â If i had enough money i would start my own machine shop.
Custom Multi-Injector setup
KevinL87tsi replied to HotrodTSi's topic in MPI/Standalone Trials and Tribulations
easier to tune because there arent many options -
you could but the cost of an eic is much less expensive than a complete standalone management system .. lets you use the stock computer for everything else and have the eic for the 4 injectors when pushing higher boost.. Â and everything fits like its stock. Â ... and no wiring up sensors, no getting magnets pressed into crank pulley and easier to tune. -
looks like a tight fit.. i doubt any angle could be put on the injectors looks great! -
what do you need for a 12 sec. car?
KevinL87tsi replied to svo's topic in Engine and Performance Mods
preferably forged pistons (to be on the safe side), jetvalveless mechanical adjuster head to rev rev rev! (uncracked), bigger cam, heavy duty valve springs, 3 inch exhaust (mandrel bent), some serious fuel additives (multi-port fuel injection), fuel management computer, a tranny that is in good shape, aftermarket clutch, lightened flywheel, blowoff valve, aftermarket boost gauge, upgraded fuel pump, bigger turbo (t3/t4, 20g), upgraded intercooler, intercooler hardpipes, rodded radiator, air fuel ratio meter, boost controller, ... looking at around 8-10k  : -
how streetable is quite streetable?
i havent gone past 10psi with my 19c... its running really rich at 10 psi... but i promised myself i wouldnt install my evc until i get a mpi.. dont want to risk it with all the $$$ pouring in
problem with flexable pipe is that it isnt smooth inside... has ridges where it flexes.. and decreases flow... which is the reason you have 3" exhaust in the first place.. flow..... i dont know how much it would effect it .. it would depend on the size of the ridges
welcome back man... cant wait to see you race another neon
another magna installed
KevinL87tsi replied to chiplee's topic in MPI/Standalone Trials and Tribulations
very nice!... ;D
