kstokes606
Everything posted by kstokes606
I am in need of a connecting rod for a G54B engine. It is a D-50 pickup truck with the 2.6 lt engine. Thanks, Ken
I need a balance shaft cover, special bolt A, Crankshaft pulley bolt, and Balance Shaft sprocket spacer, ASAP.
Anyone have a cover for the side of the block where the balancer shaft is at, under the intake?
PARTS PARTS PARTS, gm mas, magna rail, boost controller.
kstokes606 replied to 19cturbo's topic in Parts for sale
Do you have a cover for the side of the block where the balancer shaft is at, under the intake?- 100 replies
- Stock and Performance
- Injectors
(and 1 more)
Tagged with:
2nd Post
Need a speed control cable, hood prop rod, and coolant overflow tank.
To remove mine I removed the antenna cap nut and the assy should drop down. Angle the top of the antenna out of the hole and move the assy out of the hole.
OD not works after replace cylinder head, and turbo gasket
kstokes606 replied to fromji's topic in Automatic Transmissions
I got mine working now. I took he connector from, 1 and 3 and swapped them. Kick down and over drive now working again. Grnded the single connector for 4, and temp guage read max, Grounded one of the T connector wires for 3 and the overdrive switch at the transmission clicked with the key on. I will open up the harness tomorrow and post the color of the wires. Hope this will help someone. -
I have the same problem, no over drive, and I have checked both modulators, and both are working fine. Still no over drive. I had overdrive and no down shift before. Rewired the wiring due to a bad connector, and now have down shift and no over drive. Could it be inside the transmission where the problem is at ? If you find the problem, please post your findings.
How about a valve cover?- 100 replies
- Injectors
(and 1 more)
Tagged with:
Got the part I needed fast. Very nice to deal with.
Just noticed the relay panels that are between the air filters and the electric antenna. Price shipped to 28422 also.
Coolant overflow tank, antennae if you still have them. Shipped to 28422. Also what heat shield do you have?
Thanks, I got the brackets, but still need a cable.
Any word on the band/bracket
Yes, it's called a band in the parts catalog on page 5-50, fig 5-2000. I tryed to order it from a dealer on line, but they canceled the order. They did not have any of the items I ordered. I need it to get the car back on the road
Need the bracket for the anti-skid unit, shipped to 28422, ASAP
I filled the filter and got the engine in and filled the oil pan. Turned the engine over for 30 seconds, and did not build pressure. Tried again and again and still no pressure. Got the idea to check the oil cooler and no oil moving thru it. I put a funell in the passenger side of the oil cooler, and poured oil into it, untill the lines were full. Tryied again and about 10 seconds the oil pressure started going up. I will try to finish up in the morning.
Thanks, I filled the filter and put the engine in today. I will try to get finish every thing tomorow and try to get it running.
I am now at the point to where I am about to put the engone back in the car and I am trying to find a way to oil the engine before I start it. I used assembly lube on all of the inside parts and want to pressurize the engine with oil. Any ideas other then trying to start it?
How do you hook up your motor to lift it with an engine hoist?
kstokes606 replied to movin on's topic in Virtual Mechanic
I use 4 short sections of chains, about a foot long at the four coner of the head, useing the intake and exhaust studs, and the chains are then hooked to a engine hoist adapter that you can adjust the angle of the engine. Used it five times so far and getting ready to put my engine back in also. As far as the mounts, I reuse the same ones do to my budget, and have had no problems. But that is not to say I wont later. I can change the mounts any time, with out removeing the engine. I undid the two frame bolts and the center bolt, lifted that side of the engine, slide out and then slid in the replacement, lowered and bolted it down, done. This may not be correct, but it works for me, cause I'm just a shadetree/weekend machainic.lol -
Is that offer still open? I am trying to find one also, free or not. If you have a extra, let me know what the price would be.
The bearing can be pressed out of the pully, but what is the part number for the bearing, and source for the bearing?
I need the driver side motor and the ribbon inside the track that the seat belt in attached to. After I took all of the tracks off, I found out that if you take the end switch off at the windsheld A-Post , the ribbon that the seat belt bolt is on, pulls out easy. Shipping address sent PM. PM me with the shipping charges and I can paypal it to you. Thanks brother, and GOD bless.
I am still in need of the seat belt track and the driver side motor. I have paid for it once already but still have not received it yet, so I guest that I am going to have to buy another one and see I get it this time. If I get taken this time, that will be the third strick, and I am going to have to find another source for parts. Never take kindness for weakness, for what goes around, comes around. GOD bless.
