kartman74
Everything posted by kartman74
i havnt seen that video in years, now i feel old. that was when mtv actually play'd good videos, or just videos in general.
wow. thats crazy!! good job. ya carma will pay you back. how intense are the fires? ive alway's wondered. while i was going through school to fight forest fires, they told me that house fires are ALOT more intense!!! =D> =D> =D> =D> =D> =D>
aaahhh, a nother former escort dork. but ya, the xr4ti is nothing really like a cosy!!!!!! nothing like a 2400 pound, all wheel drive 250hp monster, and thats just the base i believe :shock: they go all the way up to 500hp for the rally edition :shock: :shock:
i think that a buddie of mine is buying it, if he does, im getting the flatty for the wife's new toy!!!
sounds like fun, i know what the next few weeks after work will be spent doing!!! just bought a set.
snap, found it, that was fast!!!! :shock: How to make a Manual Boost Controller....that works. I have noticed that there isn't a Tech Article on How to Make a MBC in the tech article section on DSMtuners.com. So here it is. Materials: (1) 1/2" Brass TEE (2) 1/2" Brass Fittings with 1/4" Hose Barbs. (1) 1/2" Brass Plug fitting (1) 1" medium duty Spring (test a few by squeezing them with your index finger and thumb, you want it to be resistant, but not too stiff) (1) 3/8 Metal Ball (1) 3/8-16 Allen Head bolt 1 1/2" (1) 3/8-16 Nut Tools necessary: Vice 3/32 drill bit 3/8 drill 5/16 Drill bit Small Hammer Center Punch Sharpie Black Permanent Marker 3/8-16 Tap Tap Handle Procedure: Take the Brass Tee and put the plug in the top or bottom. (doesn't matter Take the Sharpie and mark the center of the plug. Take the center punch and small hammer and indent the center of the plug. Use the center punch and hammer to indent the middle of the flat side of the tee. Use the 3/32 drill bit to drill a tiny hole on the flat side of the tee. Now, take a grinder and grind the Plug flush with the body of the Tee. Take the 5/16 drill bit and drill a hole straight through the plug using the vise to hold the TEE still. Now, Tap the hole you just drilled with the 3/8-16 Tap and handle. Take one of the 1/2" fittings with 1/4" hose barbs and put it in the side of the tee. Now take the 3/8-16 nut and thread it on the bolt all the way up it to the top where the head is. Screw the bolt TIP into the hole you just drilled and tapped. Flip the Tee over and drop the spring into the Brass Tee from the bottom (or directly opposite the bolt you just screwed in) Place the Check Ball on the end of the Spring, and put the other 1/2" fitting with 1/4" hose barb on top of the check ball. Now slowly screw the 3/8 bolt down until you feel a small resistance from the spring and check ball. Run the 3/8 nut down to the surface of the 1/2" Brass plug and secure with the appropriate wrench. Now, the barb opposite of the bolt, is fed by either the compressor housing OR the intake manifold. The barb that sticks out from the middle, now feeds the wastegate actuator. To adjust boost pressure all you have to do IS: Loosen lock nut, and turn bolt IN for more boost, turn OUT for less, tighten lock nut. I will have to post my pics later, they are currently not loaded on my computer. Enjoy safe boosting. *Not responsible for damage anyone has from overboosting due to lack of following the directions.* If problems persist such as : Boost pressure uncontrollable- Make sure hoses are sourced and plugged in properly. Boost setting to high- get a weaker spring Boost setting to low- get a stronger spring Boost spiking to much- drill a slightly bigger vent hole All parts are usually available at a Ace Hardware. Grab a sales rep and bring the required materials list with you. I know some hardware stores do not stock this stuff and will play 20 questions wanting to know WHY your needing this stuff so bad, just inform them that you are saving yourself $45 - $9.00 (worth of parts) = $36 dollars and some time by doing this yourself. You may have to check around, but parts stores DO stock this stuff, you just have to know EXACTLY what your looking for. Good luck and hope I saved alot of you some $$$. here is the link to it http://www.dsmtuners.com/forums/articles-t...ller-works.html
never done it myself, but it is the same thing that you can buy on ebay for about 15 or so bucks. most mbc's are the same. i will try to find a how to online for you and post it.
how much boost are you looking at running?? if your not looking at going crazy, you can make one with parts from home depot for about 10 bucs
To the guy who has the X-19 Fiat fetish collection
kartman74 replied to Fanta's topic in Just plain ol' B.S.
those would make a cool cruiser. or a bad sleeper -
to long to watch when drunk. will watch later
thats what i would do. you will only see it when your under the car anyway's. unless its a show car, then polish it
nope, its not that one. but that is really far. im diggin the cosworth escort in the snow!!! i would love to get a hold of one of those cars!!!
nice... you know that it is true. especialy if your maried.
i dont know why, but i want one. not diggin the purple tho.
their one of the "next best thing's since sliced bread"!!!!!
me want!!!!!!
if their good, i might be interested
http://i179.photobucket.com/albums/w316/conquest232/quest%20parts/4550.jpg is this in working order and setup for boost? if so, how much???
that sucks. my work cut my overtime today as well. now im to broke to pay attention.
actually,Rob,the best combo is a 400 align bored for a 440 crank,bored .010" with .002" titanium sleeves=451 ci. i know this 'cause i've built two and they're awesome that would be sweet. but for now, its gonna be a stock 350. running out of money, and i dont even have the tranny yet. i hate paying bills!
im in the same boat. i got most of my parts but the tranny. kinda need that one to get the mockup going. sucks man. for the both of us. just work as much overtime as your work will let you. thats what im doing!
ya, so. im from a place called kuna, if you were in idaho you would understand. but im a high tech redneck. i use more than bailing wire and duct tape.
i need swaybar bushings, and i cant find new ones at a decent price, and the local dealer cant get them. but my center front bushings rotted away, they are no more, just the hanger is their. so used ones are better than what i have now. and thanks for the apiller cover. cant wait to put it in!!!
