1988tsiturbo1 Posted December 1, 2009 Report Share Posted December 1, 2009 (edited) Ok so I have a bone stock 88 tsi and when I start it in weather below 40 it bucks, idles down and dies but after it gets warmed up its fine. Any ideas??? Replaced the spark plugs plug wires distributor cap and rotor coil Edited December 1, 2009 by 1988tsiturbo1 Link to comment Share on other sites More sharing options...
jettajody Posted December 1, 2009 Report Share Posted December 1, 2009 Ok so I have a bone stock 88 tsi and when I start it in weather below 40 it bucks, idles down and dies but after it gets warmed up its fine. Any ideas??? Replaced the spark plugs plug wires distributor cap and rotor coilPossible dieing fuel system [injectors,pump,filters], maybe even a bad CTS or TPS...... Link to comment Share on other sites More sharing options...
mistapickles Posted December 1, 2009 Report Share Posted December 1, 2009 ISC, Idle Speed Control or the little switch in the tip of the ISC Link to comment Share on other sites More sharing options...
1988tsiturbo1 Posted December 1, 2009 Author Report Share Posted December 1, 2009 ISC, Idle Speed Control or the little switch in the tip of the ISCwell I have new injectors I'm putting in today, I hope that fixes it if not ill just keep trying new things Link to comment Share on other sites More sharing options...
yakimich Posted December 1, 2009 Report Share Posted December 1, 2009 I do have the same similar problem up in Washington State where it is now getting cold. My 88 had supposedly gotten fixed by rewiring up to the injectors because I was told they were cracked and frayed. It did run great all summer season and just wouldn't start up again today. Have spark and fuel even tried removing the over the head intake to feed it fuel and no go. Other than that I can't tell you what fixes it. Link to comment Share on other sites More sharing options...
JAinsworth Posted December 1, 2009 Report Share Posted December 1, 2009 I would suggest checking the isc and resetting it first, then check the cts. Link to comment Share on other sites More sharing options...
1988tsiturbo1 Posted December 1, 2009 Author Report Share Posted December 1, 2009 I do have the same similar problem up in Washington State where it is now getting cold. My 88 had supposedly gotten fixed by rewiring up to the injectors because I was told they were cracked and frayed. It did run great all summer season and just wouldn't start up again today. Have spark and fuel even tried removing the over the head intake to feed it fuel and no go. Other than that I can't tell you what fixes it.I'm pretty sure I figured it out, I pulled the dipstick and it smelled like has which means has is pouring into my cylinders so I'm thinking fuel regulator Link to comment Share on other sites More sharing options...
1988tsiturbo1 Posted December 2, 2009 Author Report Share Posted December 2, 2009 I'm pretty sure I figured it out, I pulled the dipstick and it smelled like has which means has is pouring into my cylinders so I'm thinking fuel regulatorNope that fixed it for awhile like 2 hours but now its back to running like garbage Link to comment Share on other sites More sharing options...
mistapickles Posted December 2, 2009 Report Share Posted December 2, 2009 Nope that fixed it for awhile like 2 hours but now its back to running like garbageWhy fight it, its your ISC, it controls exactly what is making your car run bad. Link to comment Share on other sites More sharing options...
1988tsiturbo1 Posted December 2, 2009 Author Report Share Posted December 2, 2009 Why fight it, its your ISC, it controls exactly what is making your car run bad.where would that be located at haha and how can i reset it? Link to comment Share on other sites More sharing options...
1988tsiturbo1 Posted December 2, 2009 Author Report Share Posted December 2, 2009 i forgot to mention it doesnt want to start most of the time but the starter is fine but if i pop start it it turns over everytime Link to comment Share on other sites More sharing options...
mistapickles Posted December 2, 2009 Report Share Posted December 2, 2009 it's the servo that is connected to your throttle cable...I'll post some pictures when I get back from work, unless somebody can post them before me...OR you could do a search for it, Shelby has a write up somewhere on here explaining how to clean and reset them. Link to comment Share on other sites More sharing options...
1988tsiturbo1 Posted December 2, 2009 Author Report Share Posted December 2, 2009 Why fight it, its your ISC, it controls exactly what is making your car run bad.It was the fuel filter and the fuel pressure regulator swapped them and it runs perfect idles at 950 no bucking starts up right away Link to comment Share on other sites More sharing options...
KY TSI Posted December 3, 2009 Report Share Posted December 3, 2009 mine does the exact same thing ill try swapping those parts Link to comment Share on other sites More sharing options...
Baseraider Posted December 3, 2009 Report Share Posted December 3, 2009 Where did you find the fuel pressure regulator at? Autozone wants $105 for it Link to comment Share on other sites More sharing options...
1988tsiturbo1 Posted December 3, 2009 Author Report Share Posted December 3, 2009 Where did you find the fuel pressure regulator at? Autozone wants $105 for iti got it off my parts car haha only 4000 miles so i figured it would be good Link to comment Share on other sites More sharing options...
