87quest' Posted November 28, 2009 Report Share Posted November 28, 2009 i have a 1987 conquest tsi and i just put a new head gasket in...i need to re time it and i was wondering if i could get some steps...i already have the #1 at tdc and i need to know where the cam should be at Link to comment Share on other sites More sharing options...
Dad Posted November 28, 2009 Report Share Posted November 28, 2009 i have a 1987 conquest tsi and i just put a new head gasket in...i need to re time it and i was wondering if i could get some steps...i already have the #1 at tdc and i need to know where the cam should be atService manual. Free @ www.starquestgarage.com Dad Link to comment Share on other sites More sharing options...
Indiana Posted November 29, 2009 Report Share Posted November 29, 2009 Dowel pin hole almost to top. If you look at the center of the cam bolt and that dowel pin hole and follow it out to the teeth now look at the two holes in the cam tower caps for the valve cover and extend that out to the cam gear. The cam gear line can't be past the valve cover line. The cam gear line will be half tooth in front of the valve cover line. Crank pulley mark lined up with TDC mark on the timing cover. Link to comment Share on other sites More sharing options...
Indiana Posted November 29, 2009 Report Share Posted November 29, 2009 This won't work with milled surfaces, it may be off and the more milling done the more it will be off and the cam gear is moved more clockwise as that happens. Stock surfaces lining it up that way works. Link to comment Share on other sites More sharing options...
