dmyers151 Posted November 3, 2010 Report Share Posted November 3, 2010 Mike, locate the perch so that your threaded sleeve is completely filled by the strut tube and doesn't hang over with empty space at the top or have a bunch of strut tube sticking out. Link to comment Share on other sites More sharing options...
Prozaq Posted August 30, 2011 Report Share Posted August 30, 2011 (edited) KYB was not willing to help me out after contacting them multiple times in regards to purchasing the gland nuts for the conversion ("we don't sell to the public" was repeated every call). I received an old part # from their tech support to boot. They did grudgingly recommend going to Pep Boys or Carquest to order the parts. Pep Boys was unable to locate the part in their system (may have been due to the old part #), and gave me some random gland nut (qty: 1 lol) they had laying around as a consolation prize. I contacted Carquest and 15 minutes later they came back with the new part # that had superseded the KYB # I was told originally. On order, should be here by the end of the week...so...go Carquest, I'll make sure I check in with you guys for hard to find stuff first next time lol. Cliff notes:KYB gland nut part number: 575-T248 (or just google kyb t248 for results)Cost: ~$6 to $10 per I hope this helps. Screw you KYB, I will have my Konis. Edited August 30, 2011 by Prozaq Link to comment Share on other sites More sharing options...
Komeuppance Posted August 30, 2011 Author Report Share Posted August 30, 2011 Thanks for the info Prozaq. Maybe their email support is a different department than call center?? -Robert Link to comment Share on other sites More sharing options...
RF600 Posted August 30, 2011 Report Share Posted August 30, 2011 KYB sent me 2 free. I had to buy 2 more. Link to comment Share on other sites More sharing options...
D_Venable Posted August 30, 2011 Report Share Posted August 30, 2011 Prozaq, thanks for the info on where to get them. I had similar responses through emails with KYB about buying just gland nuts. Link to comment Share on other sites More sharing options...
Prozaq Posted August 30, 2011 Report Share Posted August 30, 2011 Thanks for the info Prozaq. Maybe their email support is a different department than call center?? -Robert No problem guys, I'm glad to help out. I'm guessing there are a few good ppl working in KYB that will sell through a "cash" or "will call" account for special order stuff like that, but it sounds like a lot of ppl there are in the hardline "can't sell to the public" mindset, and aren't willing to help out. Link to comment Share on other sites More sharing options...
Komeuppance Posted August 30, 2011 Author Report Share Posted August 30, 2011 I thought I posted that gland nut part number here too, but I guess it was on Austarion.com haha. My invoice only had "t248" on it. -Robert Link to comment Share on other sites More sharing options...
Prozaq Posted September 4, 2011 Report Share Posted September 4, 2011 Getting ready to do an install with Koni sport inserts and Mookeeh rear housings. I'll try to compile the notes as neatly as possible as I come across issues... - The Koni shock bodies are identical in height (from bottom protrusion to gland nut mounting surface) as the Excel's in Komeuppance's walkthrough [14 1/4"]- Mookeeh rear housings use the MR2 gland nut thread pitch (that'll save someone $16 lol) Also, I'm not quite sure what MR2 insert they designed this around (besides the one they include in their shock/housing kit), but the housing is 1/2" too short. I verified the welds at the base of the insert are coming into contact with the housing before the protrusion hits the very bottom of the housing (but it's close). I have a couple options at this point, I'll figure it out tomorrow lol. Link to comment Share on other sites More sharing options...
D_Venable Posted September 4, 2011 Report Share Posted September 4, 2011 some of us have used rear MR2 inserts (like I have) and others have used MR2 fronts (I think SFBMX88 used fronts) Link to comment Share on other sites More sharing options...
Prozaq Posted September 4, 2011 Report Share Posted September 4, 2011 some of us have used rear MR2 inserts (like I have) and others have used MR2 fronts (I think SFBMX88 used fronts) This is a pretty good point...I wish I still had my suspension install pix from my 93 MR2 so I could tell the height difference, but I did see someone mention the fronts are a touch shorter. I did want to go with a swapped set up (MR2 rear in front of SQ, vice versa) to adjust for the switch in weight bias between the two cars, but I wasn't sure if any of the aftermarket valving was different between the front and the rear shocks. I haven't really seen anyone else using Konis, and this will be my first set...so I figured I'd post what I find as I go along. What inserts have you used and which did you like? Link to comment Share on other sites More sharing options...
Komeuppance Posted September 4, 2011 Author Report Share Posted September 4, 2011 Patra_was_here might be using Konis. I'm using Tokico Illuminas, all rears. As far as weight balance, I did "the math" vs an MR2... MR2's (SW20 turbo) weight from 2750, to 3050, with a weight distribution of:Front axle: 1260 lbs (43%)Rear axle: 1660 lbs (57%) I just weighed my MR2 on the way back from buying it. I went to a truck stop that has a CAT scale, which has a precision of 20 pounds and they guarantee the accuracy (see the guarantee at the top of the weight slip photo). Results (1995 MR2 turbo M/T, STOCK w/ t-bar, leather, and 1/3 tank of gas, no driver): Front axle: 1260 lbs (43%)Rear axle: 1660 lbs (57%)Total weight: 2920 lbshttp://www.mr2.com/f...html#post188247 I don't remember exactly, but the SQ weight distribution is better at 53:47 I think. That's about 1600 front, and 1400 rear. So we are very close to what an MR2 is pushing. -Robert Link to comment Share on other sites More sharing options...
Prozaq Posted September 8, 2011 Report Share Posted September 8, 2011 That's good to see those numbers posted up; I'm surprised to see the '95 MR2 coming in sub-3k lbs...the '93-'95 models were the chunkiest by a fair bit. Still lots of fun though. Well, adding onto my previous post, there really wasn't too much to modify. Here's the list off the top of my head (YMMV, "measure twice, cut once"): -Stock front housings needed ~2 5/8" spacing to fit MR2 Koni rear inserts.-Rear Mookeeh housings need 1/2" extension to enclose MR2 Koni rear inserts (if the front MR2 shocks are 1/2" shorter like it sounds, that's the way to go)-Extension should be made above the spring perch and below the gland nut threading if you want to retain the same height-If you're using a stock spring style (non-coilover), the upper spring seat needs to be reamed out to allow the shock rod to slide through...it's D-shaped so just rounding it out does the trick.-Using a stock replacement mount on the rears (non-pillowball) may require drilling out the shock rod opening for clearance. I'm really almost appalled at how easy the rear struts come out lol. Falling in love with the Konis, too. Link to comment Share on other sites More sharing options...
sleeper tsi Posted January 2, 2012 Report Share Posted January 2, 2012 I'm gunna run mr2 rears all the way around. Is this a good or bad idea? Link to comment Share on other sites More sharing options...
D_Venable Posted January 4, 2012 Report Share Posted January 4, 2012 (edited) I'm gunna run mr2 rears all the way around. Is this a good or bad idea? that's perfectly fine, I did this on my flatty, and will have it on my fatty soon too but with the mookeeh (MK1) rear housings, sounds like MR2 fronts are the better way to go Edited January 4, 2012 by D_Venable Link to comment Share on other sites More sharing options...
SFBMX88 Posted February 7, 2012 Report Share Posted February 7, 2012 I'm gunna run mr2 rears all the way around. Is this a good or bad idea? I used MR2/Celica alltrac FRONTS at all 4 corners on mine. The Alltrac is roughly the same weight as the Starion, so fronts should work well. Maybe try fronts and rears on your setup? 1 Link to comment Share on other sites More sharing options...
Komeuppance Posted February 8, 2012 Author Report Share Posted February 8, 2012 I'm gunna run mr2 rears all the way around. Is this a good or bad idea?LOL...Patra_was_here might be using Konis. I'm using Tokico Illuminas, all rears. As far as weight balance, I did "the math" vs an MR2... MR2's (SW20 turbo) weight from 2750, to 3050, with a weight distribution of:Front axle: 1260 lbs (43%)Rear axle: 1660 lbs (57%) I don't remember exactly, but the SQ weight distribution is better at 53:47 I think. That's about 1600 front, and 1400 rear. So we are very close to what an MR2 is pushing. -Robert Link to comment Share on other sites More sharing options...
SFBMX88 Posted February 8, 2012 Report Share Posted February 8, 2012 (edited) 1988 ST165 Celica Alltrac: Curb Weight: 3270 lb (with options) Weight Distrobution F/R: 59/41 ***The MR2 KYB AGX inserts front and rear are the same length. Edited October 23, 2012 by SFBMX88 Link to comment Share on other sites More sharing options...
89BananaQuest Posted November 2, 2012 Report Share Posted November 2, 2012 Sorry i know this is okd. But the link isnt working. Does any one have a link to a how to on this? Link to comment Share on other sites More sharing options...
Coke Posted November 22, 2012 Report Share Posted November 22, 2012 Broken link. WHATS UP WIT DAT BERT? Link to comment Share on other sites More sharing options...
Komeuppance Posted November 22, 2012 Author Report Share Posted November 22, 2012 Gotta make you work for it... lol... -Robert Link to comment Share on other sites More sharing options...
Laodicea Posted December 28, 2012 Report Share Posted December 28, 2012 Get the link back up...I got work to do. Link to comment Share on other sites More sharing options...
spadey Posted January 30, 2013 Report Share Posted January 30, 2013 still no link no work:((( i got money to spend lol Link to comment Share on other sites More sharing options...
farrk007 Posted April 27, 2013 Report Share Posted April 27, 2013 Yeah...put this link up again!! please. Link to comment Share on other sites More sharing options...
dpstarion88 Posted September 12, 2013 Report Share Posted September 12, 2013 http://home.comcast.net/~driftability/gallery/StrutMod/StarionMR2Inserts.html Link to comment Share on other sites More sharing options...
The Rabbit1 Posted September 14, 2013 Report Share Posted September 14, 2013 ok, I R confused, I have stock fronts and MK1 rears, so they all should have gland nuts, and I have to order two front gland nuts and 2 rears? do the replacements called out in the walkthru and this thread screw right into the housings? or do I need MR2 upper sections that will accept the gland nuts? Link to comment Share on other sites More sharing options...
